Wireless router
Dayias
Community Member
I have a wireless router and want to add 3 more wired devices but all my ethernet port are full, does anyone know how to extended?Untitled.png
Martin L
Yes, just add l2 switch to one of LAN ports and connect reaming devices to switch.  c2950 or c2960 are l2 switches.
Regards, ML
**Please Rate All Helpful Responses **
Dayias
Community Member
The Lan port is the internet port?
no, LAN ports are those 4 Ethernet ports where you connect local devices (usually 4 ports grouped together); whereas the Internet port is the one (usually single) connecting Internet.  The idea is to share Internet traffic with 4 home devices, aka LAN devices
Regards, ML
