Wireless Router !
S_Tathare
Community Member
I need some help. Has any one used "MSI RG54G3 54G Broadband Router with 4Port switch + 1xWAN NAT/Firewall/VPN" box ?
If yes how is your experience ?
Can any one recommend a good and economical wireless box for home lab ?
wong34539
Level 11
Level 11
The economical wireless router depends on the the area where they are are used.
All low end routers are seem to be economical.
