Wireless Security using a IDSM2 at v4.1
jlwomeld
Level 3
Level 3
I'm starting a wireless project and would like to know what hardware I need, at this point I have the following HW
1130AG, WLSE,
We have a 6500 with an IDSM2 blade, what kind of security can the IDS provide for my network?
s.jankowski
Level 8
Level 8
I suggest that you LEAP on the APs. When using LEAP for user and device authentication, WEP encryption is automatically enabled and cannot be disabled. However, if added security is needed, a VPN, can provide any level of encryption desired. Using a VPN as the bridge between the wired and wireless network is recommended regardless of the underlying vendor or technology used on the wireless network.
