wireless security with zero client configuration
ahmedfouad
Dears,
i have a client that needs to have 802.1x based wireless security with zero configuration at his smart-phone devices , just needs to select the ssid prompt for authentication ,login by his domain account and that's it .
is it possible ?
Scott Fella
Yes that is possible using 802.1x PEAP MSChapv2.  This uses AD credentials so when the user clicks on the ssid, they will be prompted to use their AD credentials.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott Fella
Scott
-Scott
You can find examples on the Internet depending on what Radius server your using.
Here are some:
http://www.labminutes.com/sec0095_acs_wireless_dot1x_peap_eap_tls_machine_authentication_2
http://networklessons.com/wireless/peap-and-eap-tls-on-server-2008-and-cisco-wlc/
Scott
-Scott
thanks alot Scott , very helpful links
No problem. Let use know if you run into any other issues or have questions.
-Scott
