Wireless Security without Radius
El-Guero-HTX
We have several small sites with Roaming users and we have several SSIDs with PSK only. How are you securing sites without a Radius Server? The issue is users sometimes share SSID info via iPhone/Android. Also, we dont want to get flooded with Access requests to use Meraki Auth. Could we use Auzre AD (multiple Tenants)?
aleabrahao
Meraki Community All-Star
Maybe it can guide you.
https://youtu.be/5PDpnsWtmlE?si=hTq1vEL4w6WiMGA-
https://apicli.com/2021/12/13/meraki-mr-802-1x-with-azure-active-directory/
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
BlakeRichardson
@El-Guero-HTX Are you using PSK or iPSK? I am assuming the latter because standard PSK doesn't involve external authentication sources.
If you don't have a radius server onsite you could always use Jumpcloud which is a cloud based directory server and use 802.1x
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
