Wireless security
I have one SSID and I would like it to be used by two different recently merged network ( both network still separate from each other).
How we can accheive this one. Can we use LDAP? Any other solution on WLC or NCS?
Scott Fella
You can use LDAP I guess, but why not use radius?  I'm gussing that the AD domains are not merged or trusted, or are they?  That makes it difficult then.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
We still have 2 separate AD domains.
you have to keep in mind something very important , where you will be limited to certain authentication types if you are using WLC as local authenticator with two LDAP connections to your AD domains.
so what type of authentication you want to achieve ?
please make sure to rate correct answers
