Wireless signals
umar bhatti
Level 4
Level 4
Dear All,
I need a advise on this. Basically at home i am using normal sky router and the wireless signals are really bad in the kitchen and garage area. I want to put a device which helps in better signals. Could you please give me some suggestion about what i should you. I have seens some AP but not sure which one should i use.
17 Replies 17
Scott Fella
I don't know about adding a wireless AP that will replace your other wireless AP will help. Not knowing what signals you are seeing or the layout makes it hard to say. If you have Ethernet ran to rooms in your house you can always add an access point that way.
-Scott
Hi Scott, that's what i was thinking to run a cable and put an AP on the other end but which one.. Do you know any good one..
Scott Fella
I would look at the 1142 who h is a dual band and also support 802.11n. You can run this in autonomous mode. You can find these cheap because they are EOS. They have builtin antennas also.
-Scott
But does 1142 going to work with normal sky routers i.e. netgear etc..
Yes... Your current router will supply DJ p so you just need to configure the AP with your SSID.
-Scott
What is DJ p also do i have configure DHCP etc on the AP or is it just plug and go..
There is minor config but minimal you need. If you connect it to your router and that is already providing dhcp address to devices you should be fine. All you need to configure is your SSID.
-Scott
Also these AP are to expensive nearly £200. Is their any other you can recommand.
Scott Fella
You can always find a configuration guide on Cisco's site.
-Scott
Scott Fella
Well unless you just buy one from the local electronic store, these Cisco APs are a bit more expensive. You can look at the 1131 but that is not 802.11n. Have you looked on eBay?
-Scott
Yes proper expensive on ebay as well. Any other like dlink etc
Scott is recommending 1130!  What a shock!  What horror!  LOL
Well he wanted something cheaper:)
-Scott
Scott Fella
You can always look for a home access point instead of an enterprise access point.
http://homestore.cisco.com/en-us/access-points/linksys-WAP610N_stcVVproductId80342978VVviewprod.htm
-Scott
