Wireless Throughput
Mohammad Yassin
Frequent Visitor
Frequent Visitor
Hello
I have an issue in throughput from one AP 1572EAC.
i'm testing that in a lab now, but i have it in multiple live sites which's in all of them giving bad throughput comparing that its working on 80-Mhz and having 1G link.
in the live sites its almost reaching 100 Mbps. and in lab little bit more than that which's should be at least reaching 400 Mbps.
and that on ac radio.
On live sites i have 8510 WLC with current code 8.0.140 , and on Lab the code is 8.2.151.
all is running on 80 MHz channel width
the current parameters are :
802.11b/g/n:
1 -   Supported
2 -   Supported
5.5 - Supported
6 -   Supported
9 -   Supported
11 - Supported
12 - Supported
18 - Supported
24 - Mandatory
36 - Supported
48 - Supported
54 - Supported
802.11a/n:
6 - Supported
9 - Supported
12 - Supported
18 - Supported
24 - Mandatory
36 - Supported
48 - Supported
54 - Supported
even with changing not much of difference happening.
also i tried to change MCS values to run on SS3 alone, or SS2 & SS3 , all giving the same result.
i tried to check GI on WLC, it should be running on short interval which is 400 ns , is there a way to check this out ??
which's will support higher data rates and throughput ac or n ? because as far as i know the maximum speed can be reachable on ac.
The main question and mystery to me how i can improve and achieve high speed. ???!
Please i need an advise and help because this issue is been too long without finding an lead.
0 Replies 0
