Wireless uptime
Agus KTI
Level 2
Level 2
Where i can find wireless uptime menu on meraki dashboard, i already check all menu but can't find that. Appreciate for answer.
Thank you
6 Replies 6
Make_IT_Simple
are you looking for the WAP's uptime or for how long a device was connected to a particular WAP?
Like that so we know how long access point was connected, so i can plan for reboot device.
Thank you
Your WAP's uptime won't be visible on your dashboard, only support can see that. If you need to know any of your Meraki device's uptime, you will need to email or call Meraki support.
Thank you for the answer, i guess there is menu on dashboard like other access point brand i can see how long access point already connected, so anytime i can reboot for refresh the device.
Thank you for your time and answer.
Hi, Thanks for link.
