wireless user authentication happens on Cisco ISE
jain.manish94
Hello Team,
my wireless user authentication happens on Cisco ISE but here client is recommending one setup over the ISE where Radisu and TACACS can get only Level 5.
Can any one help me how to do this for Both RADIUS and TACACS
Manish Jain
balaji.bandi
Can you explain your own way, how you looking to setup RADIUS and TACACS
TACACS used for device authentication
RADIUS used or user authentication for 802.1x
which one is working and one that not working?
BB
all are working fine there is no issue with device authentication and user authentication.
but i want ISE will check both and assign Level 5 only for User authentication and device authentication.
not sure what is the requirement here, you need to match the user profile based on the Groups. and level of access to give.
BB
ammahend
When a user logins to a device (router/switch etc) they can login using tacacs or radius, it depends on how your device is configured and if your AAA server supports tacacs and if you have right license etc.
As part of authorization you can assign them a certain privilege level (5 in your case) but you still need to understand from your client what 5 means for them, with each privilege level you can associate a set of commands and user login to device with that privilege level can only execute those commands.
based on that information you can built authorization policy.
see this an an example for tacacs
https://youtu.be/p7AMEybyXYQ
hope this helps
-hope this helps-
