08-03-2006 06:12 AM - edited 07-04-2021 12:46 PM
Hi Everybody
We have the following senario:
- WLC 4402 and ACS 3.3
- 2 SSID's , One for Emploies - one for gests
- All users are (guest and emploies) are authentication against the ACS Server.
We would like to only permit Guest users to use the Guest SSID.
I've been reading the Wireless Virtual LAN Deployment Guide :
http://www.cisco.com/warp/public/cc/pd/witc/ao1200ap/prodlit/wvlan_an.pdf
and have tried to use methode 1.
- RADIUS-based SSID access control:
"Upon successful 802.1X or MAC address authentication, the RADIUS server
passes back the allowed SSID list for the WLAN user to the access point or bridge. If the user used an SSID on the allowed SSID list, then the user is allowed to associate to the WLAN. Otherwise, the user is disassociated from the access point or bridge."
"This is configured by enableling the ?[026/009/001] cisco-av-pair? option. On the ACS Server
- Enable and configure Cisco IOS/PIX RADIUS Attribute,
009\001 cisco-av-pair
- Example: ssid=LEAP_WEP"
I've tried this, but regardless of wich SSID the user(-group) has configured, it sill can access all SSID's?
Does anyone have any idea of what I'm doing wrong?
Does this setting only apply to Accesspoint, or is it also valid for the WLC 44xx series?
Greetings
Jarle
Solved! Go to Solution.
09-11-2006 11:42 AM
j -
What is the exact syntax for the avpair in ACS?
"ssid=ssid" in quotations?
08-09-2006 05:26 AM
Put the guest users in seperate VLAN and associating the Default VLAN ID to the native VLAN field is known as mapping the VLAN to the SSID. The mapping process is how the bridge is able to "connect" to the VLAN on the switch. So due to this only guset users will be assigned the SSID.
08-11-2006 07:03 AM
Hi I'm sorry but this still does not help.
We have now upgraded ACS to version 4.0 and I'm still having the same problems.
This is what i have configured:
WLC:
- WLAN
- SSID : Public
- WLAN id = 3
- L2 Security : 802.1x
- Interface Name : GuestVLAN
- Controller - Interface
- management - Untagged
- GuestVLAN - VLAN 112
- Security
- RADIUS Servers
When authenticating a Guest(belonging to the proper group in acs) - the right VLAN is used, IP Adresses from DHCP is recieved, and the Guest can access internet.
Switch:
- Port connected to WLC uses Trunking.
- Guests are connected to VLAN 112 and "native VLAN" is used to connect the Private Users.
ACS:
- AAA Client is the WLC, Authenticating using Cisco Airespace
- Guest Users are member of Group 11
- Private Users are member of Group 1
Group 11
- Use Per Group NAR to only allow WLAN Access
- Cisco Airespace RADIUS Attributes
x 14179\001 - Aire-WLAN-ID = 3
- Cisco IOS / PIX RADIUS Attributes
x 009\001 Ciso-av-pair = "ssid=Public"
- IETF Radius Attributes
x 006 Service Type = Login
x 007 Framed-Prot = ppp
x 064 Tunnel-Type = VLAN
x 065 Tunnel-Medium-tye = 802.1x
x 081 Tunnel-Private-Group-ID = 112
Group (default Group)
x 14179\001 Aire-WLAN-ID = 1
- Cisco IOS/PIX Radius Attrib
x 009\001 Cisco-av-pair = "ssid=Private"
- IETF RADIUS
x 008 Service-type = Login
Do you have any idea of what i should change?
Greetings
Jarle
09-01-2006 12:20 AM
I've forgotten to set "Allow AAA Override" = Enabled".
As soon as this was "checked" it worked.
(with minor issues of controller DHCP problems)
Thanx
Jarle
09-11-2006 11:42 AM
j -
09-12-2006 04:47 AM
HI no - without Quoatas : ssid=mypublicwlan Greetings Jarle
09-19-2006 04:19 AM
ssid-list is an atonomous mode feature and does not work properly in an LWAPP environment. For ssid restrictions in an LWAPP environment it is recommended to use the WLAN-ID field in the Cisco-Airespace-Radius configuration. Instead of specifying the ssid name, you specify the corresponding WLAN-ID number found on your controllers. Unfortunately, there is a AAA override bug (cscsd58434) that prevents this feature from working properly in some 3.2 and all 4.0 controller versions. The TAC workaround is to fall back to dynamic VLAN assignments. This is not a flexible enough workaround for most. Those still wishing to use SSID restrictions should use ACS Network Access Restrictions as follows:
AAA Client= Controllers
Port= *
CLI= *
DNIS= *ssidname
The * for the DNIS entry is required.
11-13-2006 01:37 AM
hi mkisiel, our senario is similar to the above one, I've configured non-ip-based nar as you suggested, however, it turns out that both users can't pass authenticate process, when I unchecked the cli/dnci nar box, both users can access any ssid. here is my configuration:
WLC:
- WLAN
- SSID : public
- WLAN id = 2
- Interface Name : public
- management - 128 (vlan id of management interface)
- public - VLAN 205
- vlan id - 205
- SSID : private
- WLAN id = 3
- Interface Name : private
- private - VLAN 204
- vlan id - 204
- Security
- RADIUS Servers
ACS:
- AAA client = WLC, use Cisco Airespace authentication
- public user assinged to Group 1
- private user assinged to Default Group
Group 1
x aaa client = wlc
x port = *
x cli = *
x dnli = *public
Default Group
x aaa client = wlc
x port = *
x cli = *
x dnli = *private
do i have to fill the wlan id in Cisco Airespace RADIUS Attributes blank? Or 64, 65, 81 attribute blanks under IETF RADIUS Attributes? I've tried all the options above, however it still doesn't work, please help!
11-21-2006 12:13 PM
Doublecheck your NAR permit or deny conditions.
Airespace parameter wlan-id can be blank. It won't have any effect anyway due to the AAA override bug. IETF RADIUS attributes won't matter b/c you are not defining IETF RADIUS as your authentication mechanism.
