wireless with anchor controller and multiple VLAN
mia.dobbeni@simac.be
Frequent Visitor
Frequent Visitor
Hello
We would like to use an anchor controller in order to setup a managed guest service. The guest service will be provided by an external partner, the APs with GUEST SSID are in the customers network in different remote locations. The idea is to have the guest users tunneled to the local controllers from where we go over a L3 network to the anchor controller located at the partner. The idea is to have a VLAN per remote location. Is this possible with one anchor tunnel or do we need to setup 1 tunnel per remote location/VLAN?
driven by technology
5 Replies 5
Scott Fella
Sure. If the SSID is different in each location, then you have an SSID to interface/vlan mapping on the anchor side.
-Scott
Well, the SSID is the same. The reason why we like to do this is:
1. The high number of clients
2. This way we know the physical location of the client
especially the second point is important
Well since you have added that information, what you do is create an SSID profile with the same SSID.  The profile should identify the site:
SSID: GuestNet
SSID Profile: Guest_Site_A
SSID: GuestNet
SSID Profile: Guest_Site_B
SSID: GuestNet
SSID Profile: Guest_Site_C
On the foreign controller, you just define one SSID profile and on the anchor you define all SSID profiles.  You probably have to use wlan id's 17+ to allow for multiple identical SSID's.
-Scott
Hi Scott,
Thanks for your reply. What is not clear to me at the moment is what I need to define on the foreign controller. Do I create 1 dyn interface per remote location? One tunnel to the anchor controller?
Mia
On the foreign, you don’t need any dynamic interface when anchoring. You just need the SSID which has a mobility anchor to the anchor controller. The anchor controller will have the dynamic interfaces for each vlan for each site.
-Scott
