Wireless wlan mapping
ammahend
At my main site,  WLAN CAFE is running and is associated with an interface group with 2 interfaces 10.10.10.0/24 (vlan 10) & 10.10.11.0/24 (vlan 11).
I have a remote site coming up, with the same vlan 10 (10.20.10.0/24) and vlan 11 (10.20.11.0/24).
Can I broadcast ssid CAFE at remote site and when users connect should get an IP from vlan 10(10.20.10.0/24) or vlan 11 (10.20.11.0/24) from remote site, without using flexconnect and without changing vlan number at any site or without buying new controller for the remote site.
I will appreciate any help and will rate valuable post !
-hope this helps-
mcselltor
Level 2
Level 2
if you connect the access points at the remote site to your WLC at the main site via CAPWAP, the traffic is send through the tunnel. In this case the routing at the main site is used (10.10.x.x).
The only possibilities to use the routing at the remote site is flex connect or a WLC at the remote site.
Torsten
