Wireless WLC Mesh Sectors
TH09
Level 2
Level 2
Hi there,
When I do "show mesh ap tree", I understand the tree but dont understand what are sectors and why are APs in different sectors? What do sectors tell us?
(Cisco Controller) >show mesh ap tree
AP Name [Hop Counter, Link SNR, Bridge Group Name, Channel, Preferred Parent]
[Sector 1]
MAP17(RAP)[0,0,default,149,None]
[Sector 2]
6c8bd3edf710 **
|-6c8bd3edf73c **
|-MAP19[2,30,default,149,None]
|-MAP27[3,48,default,149,None]
|-MAP07[3,32,default,149,None]
|-MAP39[3,43,default,149,None]
[Sector 3]
6c8bd3edf71c **
|-MAP03[1,22,default,149,None]
Scott Fella
Look at the hop number. You have 1 RAP and each sectors connect back to that RAP. Then you have multiple MAP’s that connect back to a MAP in sector 2. The hop count will show you if it’s a direct connection to your RAP or how many hops away from the RAP.
-Scott
