wireless workgroup
kevin_israel
Community Member
hi, i need to put some computers in the same workgroup to share some files, but when i finish the configuration of all computers i can't see them, they have all win xp, does anybody know why?? could be for something in the AP??
before hand, thanks
b.hsu
Level 11
Level 11
To troubleshoot this try the following ...
1. Check if you are able to ping the computers which you have configured as a part of the same workgroup.
2. If you are able to ping then there can be no issue with the wireless connectivity.
3. You have to check the workgroup configuration on the computers.
4. Work group names can be case sensitive. Check if all the computers are configured with the same name...
