Wireless workgroupbridge not working
marc.groenen
Level 5
Level 5
I have just installed new equipment on a site.
2 buildings have there connection using a wireless bridge
This wireless bridge consists of 2 x 2602 Autonomous AP's.
Switch 1 <--> AP1  << wireless >> AP2<-->Switch 2
AP1 is configured as follows:
dot11 ssid WGB
   vlan 10
   authentication open
   authentication key-management wpa version 2
   infrastructure-ssid
with also under de d0 interface
 station-role root
 infrastructure-client
AP2
has the following configuration
dot11 ssid WGB
   vlan 10
   authentication open
   infrastructure-ssid
and under de d0 interface the command
station-role workgroup-bridge
I can ping AP2 from Switch1 but i cannot ping Switch2 from Switch1.
From AP2 i can ping Switch1, AP1 and users in VLAN 10 also i can ping Switch2 from AP2 so this seems to have full connectivity.
From Switch2 i can only ping AP2 ( it is directly connected)
Switch2 does learn the MAC addresses from all the clients connected to Switch1 but cant ping them(AP2 can)
  10    1cde.a7b1.cf97    DYNAMIC     Fa0/23
  10    68b5.99f8.34d0    DYNAMIC     Fa0/23
  10    7a2b.cb41.cc89    DYNAMIC     Fa0/23
  10    f40f.1be7.13f9    DYNAMIC     Fa0/23
 320    000e.5835.0792    DYNAMIC     Fa0/23
 320    000e.5835.4088    DYNAMIC     Fa0/23
 320    000e.5836.51d4    DYNAMIC     Fa0/23
 320    0017.880a.ef89    DYNAMIC     Fa0/23
 320    1cde.a7b1.cf97    DYNAMIC     Fa0/23
 320    84b1.539e.5c81    DYNAMIC     Fa0/23
The VLAN's used are VLAN10 & 320.
VLAN10 is used for the wireless bridge but also for the corporate network.
I checked the configuration a bunch of times and im really stuck.
I tested it in my lab and it seemed to work their, the only difference is that Switch2 is a different 2960.
Appreciate the help!
5 Replies 5
Stephen Rodriguez
can you share the configuration of the port that AP2 is connected to on Switch2?
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
The configuration of the port on switch2 is
switchport mode trunk
switchport trunk native vlan 10
The configuration is the same for switch1
marc.groenen
Level 5
Level 5
Attached are the configs of the AP's and below the switchport config on both side's
Switch 1
interface GigabitEthernet1/0/24
 description *** AP1 Uplink ***
 switchport trunk allowed vlan 10,320
Switch 2
interface FastEthernet0/23
 description *** AP2 Uplink ***
Did some more testing today.
Was actually hoping it wouldnt work when i plugged it allin in the lab but it did function fine.
The only difference is Switch 2 in the lab is a Cisco 2960S 24PS-L running IOS
c2960s-universalk9-mz.122-55.SE5/c2960s-universalk9-mz.122-55.SE5.bin
At the site where it wasnt working Switch 2 was a 2960 24TC-L running IOS
c2960-lanbasek9-mz.122-50.SE5/c2960-lanbasek9-mz.122-50.SE5.bin
Unfortunately i cant test it with that exact IOS and hardware since i dont have that available.
But that shouldnt make a difference right ?
marc.groenen
Level 5
Level 5
Topic can be closed have it working know with a different configuration the cause is still unclear.
