Wireless WPA2-Enterprice use Mac address authen first?
TimeOut
I have cisco WLC and cisco ISE
and understand  WPA2-Enterprice security using user and password authentication
Question:
If we need to overwirte use mac address authentication on ISE first  on wireless WPA2-Enterprice security. Can i do it?
Because test configure ise authentication Wireless_MAB and the first rule using mac address identity group
then try to connect wireless still enter user and password
MAB through WPA2 enterprise is not possible as these 2 are separate from each other. MAB comes during association phase whereas WPA protocols, AKM comes post association.. so the options you have are -
1. Either use MAB only.
2. Use WPA2 enterprise only.
3. USE MAB+dot1x
can you more elborate
MHM
Saikat Nandy
I reckon you want to use MAB+dot1x - if my understanding is correct then you can use it.
thx for reply
but if we want to use mab only  by wpa2 enterprice   can we do ?
3. USE MAB+dot1x
