Wirelss controller issue
saquibsalahis
Community Member
Facing this issue, few APs were not working so rebooted the WLC, after reboot no APs were showing,
set the Controller to factory defaults, configured as per the cisco guide but no hope
present situation:
WLC 4404, APs:LAP1242AG-E-k9
Acess Points are on the old old network :192.168.1.0
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 4.1.171.0
RTOS Version..................................... 4.1.171.0
Bootloader Version............................... 4.1.171.0
Build Type....................................... DATA + WPS
System Name...................................... DISD-WLAN
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 192.168.1.199
System Up Time................................... 1 days 23 hrs 21 mins 7 secs
Configured Country............................... GB - United Kingdom
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +50 C
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
--More-- or (q)uit
Number of WLANs.................................. 1
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:1E:13:2A:E1:80
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
running config:
(Cisco Controller) >show running-config
802.11a cac voice tspec-inactivity-timeout ignore
802.11a cac voice stream-size 84000 max-streams 2
802.11b cac voice tspec-inactivity-timeout ignore
802.11b cac voice stream-size 84000 max-streams 2
advanced location expiry tags 1200
advanced location expiry client 150
advanced location expiry calibrating-client 30
advanced location expiry rogue-aps 1200
Cisco Public Safety is not allowed to set in this domain
country GB
dhcp create-scope DISD
dhcp address--More-- or (q)uit
-pool DISD 192.168.1.10 192.168.1.150
dhcp enable DISD
dhcp network DISD 192.168.1.0 255.255.255.0
interface address ap-manager 192.168.1.198 255.255.255.0 192.168.1.1
interface address management 192.168.1.199 255.255.255.0 192.168.1.1
interface address service-port 10.1.1.100 255.255.255.0
interface address virtual 1.1.1.1
interface dhcp ap-manager primary 192.168.1.199
interface dhcp management primary 192.168.1.199
interface dhcp service-port disable
interface port ap-manager 2
interface port management 2
logging buffered 1
--More-- or (q)uit
mesh security eap
mgmtuser add admin **** read-write
mobility group domain RFGROUP
msglog level critical
network webmode enable
network telnet enable
network rf-network-name RFGROUP
snmp version v2c enable
snmp version v3 enable
sysname DISD-WLAN
wlan create 1 DISD DISD
wlan security wpa disable 1
--More-- or (q)uit
wlan enable 1
(Cisco Controller) >show time
Time............................................. Sat Dec 7 14:39:51 2019
Timezone delta................................... 0:0
NTP Servers
NTP Polling Interval......................... 86400
Index NTP Server
