wirless solutions
The_guroo_2
Level 7
Level 7
hi guys i am vvv new to wireless specially cisco one thjough i have a good experience of R&S....now i have to deploy a wirless solutions for a small hotel...multistory having 95 rooms......now they have a adsl2 connection so guys what do u recommand which aironet i shd go for and how it will be connected to adsl2 router (normal isp) router......thanks a million
robert.wright
Level 5
Level 5
got many many many many questions ahead of you my friend.
You need to decide what type of radio you wish to deploy.. A or B/G... Newer laptops have ABG, however its not a guarantee... but if you go with A your going have a lot less interference.
You will also need to look at what the building is made out of... different materials have different path loss. Don't forget you need to supply these puppies with power, POE at the switch or do some sort of inline POE, or outlet near the AP.
Antenna selection etc need to be referenced.
Either way your looking at a rather decent sized install and you will likely want to look at the controllers or WLSE.
