WiSM and DEBUG commands
I was looking in WLC Release 4.0 Command Reference and it is saying the WiSM does not support any DEBUG commands !!!
Is this for real?
How long before it gets them?
See,
http://www.cisco.com/en/US/products/ps6366/products_command_reference_chapter09186a00806b4ca7.html
Regards, MH
globalnettech
Level 9
Level 9
which specific debug commands are you referring to (in the link you posted) ?
The commands:
debug wism wcp {data/errors/headers}
debug wcp {packet /events}
should be available...
GNT
It doesn't make much difference which DEBUG commands I talk about with WiSm since this link says NONE of them are supported ... ie. there is no DOT for WiSM next to DEBUG commands.
Look at "debug wcp" if you like - It's not supported by WiSM.
What is "debug wism" - it's not in the Command Ref. v4.0.
I agree it should ... but does it?
Regards, MH
