WiSM and GUEST web authentication
davidfranek
I have a WiSM and we use Cisco open web
authentication with a user email address.
When performing  this command via CLI:
>config network secureweb disable
>save config
> reset system
Will this make the web authentication come up HTTP instead of HTTPS ?
dmantill
Level 4
Level 4
That command is in order that you manage the unit.
However there used to be a workaround that when you disable HTTPS and SSH and you reboot the WLC the web authentication will be showed as http and no https.
Let me know if it works for you
dmantill
Level 4
Level 4
Yes this disables https for the management and quest
web authentication.
