1240AG APs
Scott_O'Brien
Level 3
Level 3
What is the best way to configure four Cisco 1240AG APs to provide roaming in a classroom block? Would it be best to use WDS, or using APs as repeaters, or some other solution.
Leo Laohoo
WDS
dmantill
Level 11
Level 11
Definitively WDS if you are using autonomous. Here is the configuration guide explaining this about WDS and fast secure roaming if needed.
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43roamg.html
Remeber that roaming is a client decision so make sure that wireless client in well configured and make sure that the wireless enviroment is well configured (ALL radio interfaces with same configuration )  and make sure that you are using non-overlapping channels. mean, 1,6 , 11 if you are using 2.4Ghz
Thanks dmantill.
I asked Scott to ask this question for me, before I created my own account. Anyway, I've managed to get WDS working, using one AP as the WDS controller, and so far one AP connecting to WDS.
I've been testing a few things, and I've noticed that authentication is a lot slower, and data speeds are also affected, when the WDS controller is also serving clients. I'm hoping that I'll be able to achieve adequate coverage with the 3 remaining APs, and keeping the first as WDS only.
For anyone else trying to set WDS up with a similar configuration, this guide helped me a lot: http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43roamg.html
Thanks again!
