wism controller does not show url redirection spalash page
susim
Level 3
Level 3
Wism controller does not show url redirection/splash page .
client takes the ip from the  dhcp server. when browsing its not going to the authentication page as usual
Thank you
Scott Fella
Can you elaborate on your issue... really hard to follow.  To me, it seems like you want to use a guest splash page.  The client associates to the open guest ssid and get's an ip address.  Now the user has to open a browser to get the portal page correct?  This has nothing to do with the WLC, but the OS on the device.  Some devices can detect if no internet is present after authentication and obtaining an address.  This means the device will automatically open a browser to present the user with the splash page.  Other devices will require the user to open a browser to get the login screen.
Scott
-Scott
Thanks scott for your reply .
you are correct , i want to use a guest splash page . once the user connect ed the ssid and open a browser , the device was redirecting to the portal . But it suddenly stopped .  I did a 'shut' and 'no shut' on interface vlan and it worked !!.
There is nothing you need to do on the WLC. My basic testing for this is using my iPhone or iPad which does open up the portal page once I join the SSID. My windows machines do not open automatically
Scott
-Scott
