Wism controller on 6500
cisco8887
Level 5
Level 5
Hi Guys,
when I type show wism status on a 6500 switch, i see slot number 19,25,35 .. ? What are they refering to as my 6500 is 6509 so only 9 modules?
Also when i am typing session switch 1 slot 5 process 1 , it is saying session refused . why ?
if a wism controller has two modules on it only why will I get prompts for 9 processors?
many thanks
cisco8887
Level 5
Level 5
found the answer
Note: Supervisor 720-3C-10GE or Supervisor 720-3CXL-10GE required to support VSS mode.
The most important change with the Cisco WiSM in a VSS environment is the way you access and manage it. In a Cisco VSS environment, a switch ID is required for many commands used to administer the WiSM2.
The slots start from 17 and ends in 29 for 13 slot chassis for Switch 1, and from 33 and ends in 45 for 13 slot chassis switch 2.
