WiSM installation problems
remco.gussen
Level 4
Level 4
I'm trying to install the WiSM in a 6509-E switch. There will be no connection between Sup720-3B and WisM. The Service Port is not getting ip address bij DHCP scope on 6509 switch.
wism service-vlan 51
wism module 8 controller 1 allowed-vlan 50,51,64,66,68,70,72,74,76,78,80,82,84
wism module 8 controller 1 allowed-vlan 86,88,90,92,94,96,98,100,102,128,130
wism module 8 controller 1 allowed-vlan 132,144
wism module 8 controller 2 allowed-vlan 50,51,64,66,68,70,72,74,76,78,80,82,84
wism module 8 controller 2 allowed-vlan 86,88,90,92,94,96,98,100,102,128,130
wism module 8 controller 2 allowed-vlan 132,144
wism module 8 controller 1 native-vlan 51
I configured a layer 2 and layer 3 VLAN 51 and assigned ip address to the SVI..
Service Vlan : 51, Service IP Subnet : 10.200.51.1/255.255.255.248
WLAN
Slot Controller Service IP Management IP SW Version Status
8 1 0.0.0.0 0.0.0.0 Service Port Up
8 2 0.0.0.0 0.0.0.0 Service Port Up
Also Session slot 8 pro 1 is not possible..
What can be wrong ?
Remco
ericgarnel
Level 11
Level 11
have you enabled dhcp on the 6509?
service dhcp
Session slot 9 pro 1 will not be possible until you can assign it an ip address
Service DHCP is enabled (by default)...
