07-21-2016 04:53 AM - edited 07-05-2021 05:28 AM
Hello everybody,
WISM 1 Slot 2 is not reachable via its management ip address.
Only via service ip reachable.
(WiSM-slot28-2) >show logging
*nim_t: Jul 06 07:47:23.087: %SIM-3-PORT_UP: sim.c:9982 Physical port 4is up!.
*nim_t: Jul 06 07:47:23.084: %SIM-3-PORT_UP: sim.c:9982 Physical port 3 is up!.
*nim_t: Jul 06 07:47:23.082: %SIM-3-PORT_UP: sim.c:9982 Physical port 2 is up!.
*nim_t: Jul 06 07:47:23.079: %SIM-3-PORT_UP: sim.c:9982 Physical port 1 is up!.
*sshpmMainTask: Jul 06 07:47:22.955: %SSHPM-3-IN_WCP_CONFIGURED: sshpmrules.c:2199 Inbound WCP rule already configured
*fp_main_task: Jul 06 07:47:22.858: %CNFGR-3-INV_COMP_ID: cnfgr.c:2221 Invalid Component Id : Unrecognized (77) in cfgConfiguratorInit.
*fp_main_task: Jul 06 07:47:22.769: %LOG-3-Q_IND: rrmCfg.c:1501 RRM LOG: Airewave Director: Configuration has been sanitized -- save configuration to commit
*fp_main_task: Jul 06 07:47:22.562: %RRM-3-RRM_LOGMSG: rrmCfg.c:1501 RRM LOG: Airewave Director: Configuration has been sanitized -- save configuration to commit
*fp_main_task: Jul 06 07:47:16.797: %MM-3-MEMBER_ADD_FAILED: mm_dir.c:926 Could not add Mobility Member. Reason: IP already assigned, Member-Count:1,MAC: 00:00:00:00:00:00, IP: 0.0.0.0
*fp_main_task: Jul 06 07:47:16.588: %DTL-3-DSNET_CONF_FAILED: dtl_ds.c:424 Unable to set symmetric mobility tunneling to disabled on Distribution Service interface.
*fp_main_task: Jul 06 07:47:01.575: %CNFGR-3-INV_COMP_ID: cnfgr.c:2221 Invalid Component Id : Unrecognized (36) in cfgConfiguratorInit.
*mfpKeyRefreshTask: Jul 06 07:47:01.574: %SSHPM-3-NOT_INIT: bsnrandom.c:636 Random context not initialized
NW-SW0-1#show wism status
Service Vlan : 323, Service IP Subnet : 10.243.123.1/255.255.255.240
WLAN
Slot Controller Service IP Management IP SW Version Status
28 1 10.243.123.7 10.243.48.11 7.0.240.0 Oper-Up
28 2 10.243.123.8 10.243.48.12 7.0.240.0 Oper-Up
41 1 10.243.123.9 10.243.48.13 7.0.240.0 Oper-Up
41 2 10.243.123.10 10.243.48.14 7.0.240.0 Oper-Up
Reboot done, same problem.
Any ideas?
Thanks a lot & Best Reagrds
Martin
Solved! Go to Solution.
07-21-2016 08:41 PM
What does your switch port configuration look like up to the box.
07-21-2016 03:11 PM
What happens if you try to get in using the Service Port: session slot <X> processor 1
07-21-2016 08:41 PM
07-22-2016 12:59 AM
Hi George,
I dont think, the Problem is the Port Konfiguration- but I can check.
Management is untagged at all WISMs.
There are 4 WISM Slots and 3 of them work well.
Interessting thing:
The first "problem" was -> Accesss Points have connection problem with this wism slot.
Then reboot this slot via GUI Management IP. After, the management IP is no longer available.
Thanks and Best Regards,
Martin
07-22-2016 03:02 AM
Ports was in suspended mode
07-23-2016 06:59 PM
You good now?
07-22-2016 12:51 AM
Hi Leo,
when I try to connect to Service Port - it works.
BR, Martin
