WLAN 4404 Controller
lashkery
Frequent Visitor
Frequent Visitor
What are the configuration that I can have as I have orered 2 Wlan 4404 controller with same spec specially to have redundancy / failover.
ankbhasi
Hi Friend,
When APs join controller you can define primary controller and secondary controller for each specific APs so that if by any chance any controller is unreachable APs can join second controller with minimal downtime.
Also you can configure mobility group between 2 controllers so that when client roams to different APs on different controller they can retain thir ip address.
To read more about mobility solution read this link
http://www.cisco.com/univercd/cc/td/doc/product/wireless/control/c44/ccfig41/c41mobil.htm
Ankur
*Pls rate all helpfull post
