WLAN basic design questions
aghazi
Community Member
I have few WLAN questions, and would highly appreciate your expert opinion.
1. Please let me know if I can connect access point antennas with the PCI client adaptor. Also can I extend the built-in 2.2 dbi dipole antenna using low loss cable upto 20 ft.
2. Can I connect any of the AP or bridge antennas with the workgroup bridge.
3. Can I connect a 350 bridge to another 350 bridge and a workgroup 350 bridge simultaneously. I assume that the central 350 bridge needs to act in an AP as well as bridge mode at the same time, please confirm.
thanks,
Ahmer Ghazi
m.singer
Level 7
Level 7
Answering your second question, you can connect both the antennas but the AP antenna would be a better fit since WGB is going to associate with an AP.
