WLAN connection
AdrianDutu
Community Member
I have 6 wireless intermec devices 730A and 730B that  connect to two 1242 access points.The problem is that after a while the devices have no ping  response although they are authenticated to the AP and they work after  the reload of the AP config.Please help me with this problem.
Thank you in advance!
5 Replies 5
Nicolas Darchis
WLC or IOS APs ?
IOS
Soooo what IOS version are these APs running on?
Version 12.3(4)JA
I had several similar issues with intermec devices on old IOS like that.
I would suggest upgrading to 12.4.25
