WLAN Controller 4404
jlzfeeney
Level 2
Level 2
Anyone know if the ability to program the controller to become a part of an AD domain so it can use LDAP?
ericgarnel
Level 11
Level 11
not sure about that, but you can use radius.
I have not tried radius against IAS (microsoft radius), but I do know that IAS works fine with our Cisco PIX vpn setup. Delete or disable a user in AD, and IAS behaves accordingly.
Great idea on IAS, let me see if I can work that solution.
Radius/IAS worked perfectly. Thanks for the idea.
