WLAN CONTROLLER 5500 DHCP problem
dvharley00
Community Member
Hi, we have a WLC 5500 and 35 AP aironet 1042n, and upgrade our active directory and dhcp server to win 2012 R2, the problem is with aironet ap, they dont take ip from win 2012 dhcp. the win 2012 have 7 scope for our 7 vlan's and dont have problem with other vlan only with vlan for the ap.
Pls help with this problem.
Jon Marshall
I suggest you move this to the Wireless forums where you are more likely to get  the help you need.
Jon
Rasika Nayanajith
Have you configured the "ip helper adderss" on these SVI on your L3 switch ?
If you configure one of this vlan on a switch port & connect a PC (wired connection) do you get an IP on that vlan ?
Rasika
