WLAN Controller - Configuration backup
engineer_msu
Level 3
Level 3
I need to take the backup of configuration file for WLAN Controller 4420, I tried all the possibilities given in the documantation but the backup fails, I have main confusion with the file name to be backedup, i am not able to findout the configuration filename any where even when i use CLI, please help.
Saravanan Lakshmanan
from cli, show run-config commands.
from gui, before exporting the file, from drop down select config file and type any name which will be used to name the backedup file.
