WLAN Controller on remote WAN?????
pepsico_anz1
Community Member
Hi Guys,
In the event of a WLAN controller, can the APs assosiate to a controller a thousand miles away?
The backup controller would be located in the DC where 100% of traffic is destined anyway so bandwidth is not of major concern.
andrew.prince
Level 11
Level 11
Yes....BUT the maximum round trip time allowed is 100ms between AP and WLC. Also it may be best to set the AP's in H-REAP also
thanks!
round time is ok, for all but one site, 4000+km away, 65ms with no traffic....often much higher
ill read up on h-reap, cheers
no problem - glad to help
if you read this:-
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40hreap.html
it will give you alot of good information - but this is for WLC ver 4.0 - in 4.1/4.2 & 5.0 you get more functionality for H-REAP!
