Wlan controller
adeebtaqui
Level 8
Level 8
Is wireless lan controller required when deploying 40 2700access points through 4 2906x switches ( 1switch per 10 APs)?
Will  a single 2500 wlan controller connected to one of the switches be sufficient for this?
Sandeep Choudhary
Yes one WLC will also work but make sure that this WLC have enough AP license.
Info: Better to buy  two wlc for the sake of redundancy.
AIR-CT2504-50-K9      - primary
AIR-CT2504-HA-K9     -  Secondary
*** secondary WLC is not so expensive, so I will recommend to buy this one with HA license .
Don't forget to rate helpful posts
Can we deploy the access points without the WLC? Is WLC a must or only required for centralized management
Of course you can but 40 APs without WLC is not a good solution.
How will you manage these APs?
WLC is best device to mange configure APs.
If you WLC then you just need to plug/play APs(zero conifg).
Thanks a lot for clearing my query. Have great days ahead!!
