WLAN Controller
Muhammad0
Community Member
Is it possible to integrate Active Directory with Cisco WLAN Controller???
5 Replies 5
Sandeep Choudhary
you can use LDAP to join WLC.
Check these links:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/100590-ldap-eapfast-config.html
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/108008-ldap-web-auth-wlc.html
Dont forget to rate helpful posts
shall i follow this both doc or any one???
follow any one and try to join LDAP to WLC.
its done and asking for username and pass but any user n pass is not working
its done and asking for username and pass in browser but any user n pass is not working
