WLAN Override not working
cowetacoit
I have a WLC 4402 and WCS with a total of 10 WLANS. About half aren't broadcasted. At certain sites i have only 1 or 2 WLANS broadcasted by using the WLAN Override function and it is working. I added a couple more AP's at a new site and i can't get the WLAN override to work correctly. I have 2 WLANS that show up no matter what unless i disable override all together. I also broke another AP at a different site trying to troubleshoot. it is doing that same thing. any suggestions?
cowetacoit
NM. I was only going into one of the 802.11 interfaces. i figured it out. One WLAN override was enabled but the second was still disabled.
