Wlan's and LAN's vlan best practice discussion
Tibor M
Hi all,
I would like to discuss what is the best practice now for assigning vlan on WLAN and LAN (considering cisco switches and WLC)?
Are you using same VLAN as for wired connection as for WLAN? or do you have lan in different vlan then wlan?
what about mobile phones? are you using same SSID as for laptops or have different one?
I would like to have easy to use network where doesn't matter if I'm on Wifi or LAN, I will be able to use all TV's in office for streaming chromecast/dlna etc...
it is a good idea to create separate network for security and performance reason.
 It is a good idea to have a specific SSID for voice. There are some configuration for voice that it is not necessary for that.
-If I helped you somehow, please, rate it as useful.-
Leo Laohoo
Our wired and wireless clients are on different subnets.  AP are on their own little subnet and also on their own VRF.
We have ISE to determine if the wireless client is a SOE or not.  If SOE, ISE punts the client into corporate VLAN.  Same goes with BYOD or non-SOE.  Guest users goes to another VLAN.  Wireless VoIP handset have their own SSID since authentication is based on PSK (soon to be private-PSK).
Medical devices is a mad-house because various medical equipment do not have any concept with wireless networking ... and the majority only supports PSK.  So these devices have their own little "world" of SSID and subnet and are heavily "corralled"in a firewall environment.
