Wlan schedual
meirelyahu
Community Member
Is there an option to limit WLan network to be enabled only on specific time period? ( 9:00 to 17:00 ). I'm using WLC4404 version 5.0.148.0
thank you
Meir
7 Replies 7
sschmidt
Currently this feature does not exist. You can schedule a radio interface to be on/off on a schedule but doing the same with an entire wlan is not possible.
ok,
How do I schedule the radio interface?
Meir
Thank you for your help!
ericgarnel
Level 11
Level 11
If all the radios are on PoE switchports, you could write a script that turns off the switchports and run it through a cronjob
talmadari
Level 3
Level 3
While using only the WLC (controller) you can't schedule work time for the WLAN.
If you will use the WCS you can schedule to enable specific (or all) SSID's on a specific (or all) AP's.
I have WCS.
How can I Schedule specific SSID?
