WLAN SSID Issue
chandogetrude
Community Member
I have a WLC 5508 runing 8.2.141.0
Presently we have created one SSID and it assigned to four APS with different AP groups defined as per location.
We have created a guest WLAN and assigned its dynamic interface but the SSID is not seen/broadcasted
Please advise how to go about this as we need the guest WLAN to be seen from all APs
Scott Fella
So the SSID is enabled and broadcast is defined, the AP's are in the correct AP group with the proper mapping. The AP's in FlexConnect mode? Is the guest tunneling back to the controller?
-Scott
-Scott
Yes the SSID is enabled and broadcast is defined and the APs are in correct group but the APs are in local mode
Did you add the guest WLAN  manually in all AP groups.
Dont forget to rate helpful posts
