WLC+16 APS *THE WIFI CLIENTS DOES NOT ASSOCIATE TO THE STRONGEST AP SIGNAL
giovanni.cock
hi, i am working with a WLC 4102, and i have about 16 aps (lwapp) installed in different locations, but i have a big problem, when a wifi client is already associated to and ap, this wifi client does not associatte to the ap with the bigger signal. how can i solve it?
ssoberlik
Level 4
Level 4
Roaming is primarily based in client decision. Try upgrading driver and firmware on the client.Different venodrs various stratagies for roaming. You should look for specific parameters on client.
George Stefanick
What is your client ?
1242 non root bridge.
