09-27-2013 04:48 AM - edited 07-04-2021 12:57 AM
Hi there
I am unable to configure Guest LAN as in this link
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808ed026.shtml
because my Cisco WLC 2112 version 7.0.240.0 does not have the option for Guest LAN. Is Guest LAN supported for WLC 2100 series? Any workarounds or suggestions?
Thanks for your help
DIego
Solved! Go to Solution.
09-27-2013 03:22 PM
Diego,
Wired guest access is not supported on WLC2106.
Reference:
consider using a WISM, WLC4400, 3750 integrated WLC or a WLC5500
09-27-2013 12:28 PM
Please find the relevant doc to configure guest WLAN:- Please go to controller and interface to configure the same.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008070ba8f.shtml
09-27-2013 03:22 PM
Diego,
Reference:
09-29-2013 04:24 AM
Hi Shankar,
Thanks for your help. I will then explore the possibilities using packetfence.org
Thanks Jha, I might not expressed myself correctly as I was asking for wired guest access.
Regards, and thanks again both !
Diego
