WLC 2500 new interface DHCP configuration and switch trunk port config
James Simpson
Hi All
I have been working on existing WLC 2500 with a single individual interface with a handful wlan Ids.
The interface is the management 192.168.120.0/25 192.168.121.10 the management interface
I wanted to create an additional ID that would be dishing out a different DHCP scope vlan 121
192.168.121.0/25 GW 192.168.121.1
ive managed to create this interface and create a new ssid to associate with it
when I connect to the SSID I get the correct DHCP range from 192.168.121.x
The switchport that was originally connected to the LAN controller was an access port vlan 120
However now ive got a 2nd interface it needs to be a trunk
switchport mode trunk
switchport trunk allowed vlan 120,121
switchport trunk native vlan 120 (not sure if this is necessary)
Now I beileve I need to do something on the interfaces
the management (120 default) is marked as untagged
the new vlan is marked as 121
Does the existing vlan 120 now need to be taken out of untagged and marked as vlan 120 ?
also is that not the only existing config I need to do on the controller ?
Many thanks
8 Replies 8
Rasika Nayanajith
Current management interfaces is configured with vlan 0 (ie "untagged" on wlc side) then you have to make sure "sw trunk native vlan 120" is configured when you convert switchport to trunk mode.
If you tagged management interface to vlan 120, then you remove "sw tr native vlan 120" from switchport config.
Rasika
*** Pls rate all useful responses ***
Rasika
Thanks for your response
I did do this and the ssids disappeared and the WLC came offline. Is there something else additionally that needs to be done. Does the WLC or Aps need to be power cycled
No need to power cycle AP or WLC.
Do you have access to WLC console. Then post " show interface detail management" output and from the switch "show run interface gx/x" where Gx/x is the interface connect to WLC
Rasika
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 10:f3:11:a4:96:00
IP Address....................................... 192.168.120.10
IP Netmask....................................... 255.255.255.128
IP Gateway....................................... 192.168.120.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
Link Local IPv6 Address.......................... fe80::12f3:11ff:fea4:9600/64
STATE ........................................... REACHABLE
Primary IPv6 Address............................. ::/128
STATE ........................................... NONE
Primary IPv6 Gateway............................. ::
Primary IPv6 Gateway Mac Address................. 00:00:00:00:00:00
STATE ........................................... INCOMPLETE
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 192.168.120.10
--More-- or (q)uit
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
DHCP Option 82 bridge mode insertion............. Disabled
IPv4 ACL......................................... Unconfigured
IPv6 ACL......................................... Unconfigured
URL ACL.......................................... Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
Here is new interface
(Cisco Controller) >show interface detailed XXXXX-inXXX
Interface Name................................... XXXXX-inXXX
MAC Address...................................... 10:f3:11:a4:96:04
IP Address....................................... 192.168.121.10
IP Gateway....................................... 192.168.121.1
VLAN............................................. 121
NAS-Identifier................................... none
--More-- or (q)uit
AP Manager....................................... No
3G VLAN.......................................... Disabled
L2 Multicast..................................... Enabled
Please see also the trunk config
interface GigabitEthernet1/0/11
description Wifi Controller
Many thanks
Best way to do it,  tag management vlan to 120 & remove "sw tr na vl 120" under switch port.
(WLC) config interface vlan management 120
Once you do that, you should be able to access WLC
Pls test
Rasika
Sorted
One should remember to tell a port that it is a trunk
switchport mode trunk :)
Thank you for your help
