WLC 2504 and HP Procurve
tahequivoice
Level 2
Level 2
Having an issue with connecting the WLC to an HP
Vlan 1 data
Vlan 2 voice
Vlan 10 WLC
What are the settings on the HP to connect to the WLC?
Stephen Rodriguez
To an extent it depends on the config of the management interface.  If you have the management set to be 0, then:
Tag 1
Tag 2
no tag 10.
If you have all interfaces tagged then,
notag 1
tag 2
tag 10.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
The Management is set to untagged. So the first settings group is what the switch is set to.  I will pass this one, thanks.
