Bookmark
Subscribe
3429
WLC 2504 - AP's Crash every week or less
sysa
Our setup is a 30 AP's connected to WLC 2504.
We have constant complains from clients that wifi gets disconnected every day.
Checking into the AP crash log, i've identified few AP's are being crashed due to some memory leak logs attached, see lines:
Corrupt block at E56F634 (magic FF00084C)
Corrupted magic value in in-use block blk E56F634
Unexpected exception to CPU: vector 700, PC = 0x13468C0 , LR = 0x1346858
WLC Model: AIR-CT2504-K9
Software Version: 8.3.133.0
Field Recovery Version: 7.6.101.1
AP: AIR-CAP1702I-I-K9
And what does the external logger log?
I'm asking because the .pcap files are actually network capture files, which you could open in Wireshark. Or do you mean with an external logger a Netflow capable device where you log all the traffic?
If so, could you, just for testing, disable this for a few APs and check if the crashing stops?
13 Replies 13
Sandeep Choudhary
Could be a bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur62548/?rfs=iqvred
Contact cisco TAC and try to find a solution.
Dont forget to rate helpful posts
Leo Laohoo
Post the complete output to the command "sh core summary".
(Cisco Controller) >show core summary
Core Dump upload is disabled
There were various crash bugs fixed in 8.3.140.0 (and 8.3.141.0), you might want to try that:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83mr4.html#resolved-caveats_83mr4
Nearly all of those were fixed for the newer AP generation though.
Here you find the manual on how to enable crash dump uploads: https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-2/config-guide/b_cg82/b_cg82_chapter_0110100.html
@patoberli - thanks, which version do you recommend installing for 2504, that includes the proper fix for this symptom?
There are too many versions on the download page:
8.3.141.0, as you are already running 8.3.x.
EDIT: I don't know if this will fix your issue though! But it will fix many other potential bugs.
@patoberli
I've upgraded our version to 8.3.141.0, a day passed, and again another AP crashed:
11:23:17 UTC Wed May 9 2018: Unexpected exception to CPU: vector 1400, PC = 0x12D25F8 , LR = 0x125BEFC
-Traceback= 0x12D25F8z 0x125BEFCz 0x2C5C6E4z 0x2C5ECB8z 0x12E2180z 0x1D77BFCz 0x1D7ADECz 0x153AB38z 0x2E4B098z 0x2E5D6BCz 0x2E57A28z 0x2E56E98z 0x1465418z 0x1461014z 0x1461014z 0x14654E0z
Can you check if you have more information about the crash?
It should be here: Management -> Tech Support -> AP Crash Log
There is a possibility it's disabled by default, but I currently can't remember where to enable it. Might provide more information.
@patoberli
n Mar 1 1993
CMD: '02820101 00F4364B 42023267 DE493DF2 153BC145 69E9094E 16B948B4 471EE82A' 00:00:38 UTC Mon Mar 1 1993
CMD: '5B7D8A5E 2DD51E65 DB80A3E4 B4A2DCD3 949C12D8 194C859B 5A72EF6F 5297E65B' 00:00:38 UTC Mon Mar 1 1993
CMD: 'DC3B9D0A 3DCD54F7 7B23EE84 5FFAFFD4 C4755067 EF9CDBE4 27D5F84E A577E7C7' 00:00:38 UTC Mon Mar 1 1993
CMD: '9EE3E217 206EF870 C3251777 EF73A9FB DE7B21DA 16C8FBC3 F211D1D4 7246149D' 00:00:38 UTC Mon Mar 1 1993
CMD: 'C924A060 D1449C2F 8242C257 AEF7C5EA FF23E502 A0611316 BB6B6FDF A9299903' 00:00:38 UTC Mon Mar 1 1993
CMD: '4BD9206D 5B05F599 63C66D49 E4F12A0D DE5B29D5 FB112569 B1EA4C33 1859FFB6' 00:00:38 UTC Mon Mar 1 1993
CMD: 'A1BB3860 1E6520D4 DB6201F2 4444CFE9 3F17AFA4 ED0F4877 EB9E0E50 7716FB59' 00:00:38 UTC Mon Mar 1 1993
CMD: '9E06EFE3 72D96E30 AA697928 D5B6BA1F E6FB7EA5 B9028348 900008EC 2F4A9CCD' 00:00:38 UTC Mon Mar 1 1993
CMD: '3DF268D5 EF020301 0001A382 01873082 0183300E 0603551D 0F0101FF 04040302' 00:00:38 UTC Mon Mar 1 1993
CMD: '01063012 0603551D 130101FF 04083006 0101FF02 0100305C 0603551D 20045530' 00:00:38 UTC Mon Mar 1 1993
CMD: '53305106 0A2B0601 04010915 01120030 43304106 082B0601 05050702 01163568' 00:00:38 UTC Mon Mar 1 1993
CMD: '7474703A 2F2F7777 772E6369 73636F2E 636F6D2F 73656375 72697479 2F706B69' 00:00:38 UTC Mon Mar 1 1993
CMD: '2F706F6C 69636965 732F696E 6465782E 68746D6C 301D0603 551D0E04 1604147A' 00:00:38 UTC Mon Mar 1 1993
CMD: 'D77995CA BB482BB8 5514FDA3 C00FBCA7 0F961930 41060355 1D1F043A 30383036' 00:00:38 UTC Mon Mar 1 1993
CMD: 'A034A032 86306874 74703A2F 2F777777 2E636973 636F2E63 6F6D2F73 65637572' 00:00:38 UTC Mon Mar 1 1993
CMD: '6974792F 706B692F 63726C2F 63726361 6D322E63 726C307C 06082B06 01050507' 00:00:38 UTC Mon Mar 1 1993
CMD: '01010470 306E303E 06082B06 01050507 30028632 68747470 3A2F2F77 77772E63' 00:00:38 UTC Mon Mar 1 1993
CMD: '6973636F 2E636F6D 2F736563 75726974 792F706B 692F6365 7274732F 63726361' 00:00:38 UTC Mon Mar 1 1993
CMD: '6D322E63 6572302C 06082B06 01050507 30018620 68747470 733A2F2F 746F6F6C' 00:00:38 UTC Mon Mar 1 1993
CMD: '732E6369 73636F2E 636F6D2F 706B692F 6F637370 301F0603 551D2304 18301680' 00:00:38 UTC Mon Mar 1 1993
CMD: '14C900F9 1F8A1FC2 66BDA5D2 6D650E22 2E34C305 A0300D06 092A8648 86F70D01' 00:00:38 UTC Mon Mar 1 1993
CMD: '010B0500 03820101 00735936 AC7E984F 88EE171B 3DABB39B CDF70A6C DBCEC83B' 00:00:38 UTC Mon Mar 1 1993
CMD: '1A53B6AF E081C55E 69FF2717 E706652F 631008D8 7C77C516 F42AD1B5 24691F7D' 00:00:38 UTC Mon Mar 1 1993
CMD: '08D502D0 5BA135F2 9CB690B2 8FE38F8E 993AE6C8 17CCBA1E 8DE74C0B FB43A547' 00:00:38 UTC Mon Mar 1 1993
CMD: '92A48275 90A556EF 75CDB1D5 F4515843 32718F0D 50801D1A E08B52E3 285D9A09' 00:00:38 UTC Mon Mar 1 1993
CMD: '77A03344 71BDEDAD 07B3AD0D FFF39EFF 212A8119 52C46CA1 CEBBC1FA CCE2E1C4' 00:00:38 UTC Mon Mar 1 1993
CMD: '0819D3C6 9ED68410 409A3092 2D086DDF 8B44B1A8 BED1302E 0F32CAA8 93206BDE' 00:00:38 UTC Mon Mar 1 1993
CMD: 'ED514BDA C45AF19D EB2BDB65 C0A547DA 4A4528D0 1E377ADF 285AABD3 FC1E4747' 00:00:38 UTC Mon Mar 1 1993
CMD: '322A998B 32B4814C 165CC507 09098178 5FA14EFF 7D8A3AA7 3124520E 28654852' 00:00:38 UTC Mon Mar 1 1993
CMD: '3BC0BE2A 0EAA876E 73' 00:00:38 UTC Mon Mar 1 1993
CMD: 'quit' 00:00:38 UTC Mon Mar 1 1993
CMD: 'end' 00:00:38 UTC Mon Mar 1 1993
CMD: 'crypto pki trustpoint cisco-m2-root-cert' 00:00:38 UTC Mon Mar 1 1993
CMD: 'revocation-check none ' 00:00:38 UTC Mon Mar 1 1993
CMD: 'rsakeypair Cisco_IOS_M2_MIC_Keys' 00:00:38 UTC Mon Mar 1 1993
CMD: 'primary' 00:00:38 UTC Mon Mar 1 1993
CMD: 'crypto ca certificate chain cisco-m2-root-cert' 00:00:38 UTC Mon Mar 1 1993
CMD: 'certificate ca 3' 00:00:38 UTC Mon Mar 1 1993
CMD: '30820313 308201FB A0030201 02020101 300D0609 2A864886 F70D0101 0B050030' 00:00:38 UTC Mon Mar 1 1993
CMD: '2B310E30 0C060355 040A1305 43697363 6F311930 17060355 04031310 43697363' 00:00:38 UTC Mon Mar 1 1993
CMD: '6F20526F 6F742043 41204D32 301E170D 31323131 31323133 30303138 5A170D33' 00:00:38 UTC Mon Mar 1 1993
CMD: '37313131 32313330 3031385A 302B310E 300C0603 55040A13 05436973 636F3119' 00:00:38 UTC Mon Mar 1 1993
CMD: '30170603 55040313 10436973 636F2052 6F6F7420 4341204D 32308201 22300D06' 00:00:38 UTC Mon Mar 1 1993
CMD: '092A8648 86F70D01 01010500 0382010F 00308201 0A028201 0100D806 2521134F' 00:00:38 UTC Mon Mar 1 1993
CMD: '8D3A757C E93DC874 413B4DA0 65F9C2BF 9484EF6B 0B7187D4 58C26032 2CBACCBA' 00:00:38 UTC Mon Mar 1 1993
CMD: 'BB6334DB B312426A 798586B3 E87FC992 8BE3A737 45D39483 686520DB 8AD44341' 00:00:38 UTC Mon Mar 1 1993
CMD: 'DFCA4CD4 D710CD68 2795724E 744A54F5 DA71E9A5 AF4D0CB1 6C31FB0C DE73829A' 00:00:38 UTC Mon Mar 1 1993
CMD: '50095E0E E335BEBA 4EC2CAE0 6EC8842D 8AB3EE92 EC0482E4 C76E4D18 B5E964CB' 00:00:38 UTC Mon Mar 1 1993
CMD: '6486D2F0 B8E15916 3AA62648 05EE6329 1E1583EF 1E79C182 0029D456 8F0A6DC2' 00:00:38 UTC Mon Mar 1 1993
CMD: 'C858392D 63B87180 3AE1DCEB B3135222 05514700 88876DED D13CD7B8 DA857924' 00:00:38 UTC Mon Mar 1 1993
CMD: 'C62A5D1D F2834D81 1FA7CDD4 198EAB69 40E6FB07 0AF28E65 3E6DE53D C132EE06' 00:00:38 UTC Mon Mar 1 1993
CMD: '262DECBB 1EB14562 512BF059 1731721A CC0074C3 0CBB84CA 73AD0203 010001A3' 00:00:38 UTC Mon Mar 1 1993
CMD: '42304030 0E060355 1D0F0101 FF040403 02010630 0F060355 1D130101 FF040530' 00:00:38 UTC Mon Mar 1 1993
CMD: '030101FF 301D0603 551D0E04 160414C9 00F91F8A 1FC266BD A5D26D65 0E222E34' 00:00:38 UTC Mon Mar 1 1993
CMD: 'C305A030 0D06092A 864886F7 0D01010B 05000382 0101007A BE3C8D27 E8CDE492' 00:00:38 UTC Mon Mar 1 1993
CMD: '1CA68B30 6EC1D9D6 891AC3C0 9975F74E B582C895 2259B7A0 A8508E59 190B6F16' 00:00:38 UTC Mon Mar 1 1993
CMD: 'D90FF219 274D504D DEF46D0C E6745C74 F1447F82 92BC5C5E E3B37E25 A38BB910' 00:00:38 UTC Mon Mar 1 1993
CMD: '3C6B5D5D 3E693BDC A85BEDA7 C2BAE8C2 F768CB28 8B707291 CF2C3FBA 75597333' 00:00:38 UTC Mon Mar 1 1993
CMD: '52198294 ED709ED2 67147631 1B26A6A9 F97E7B19 B6E2A752 A2D453EA 6F867833' 00:00:38 UTC Mon Mar 1 1993
CMD: '07C1DE7D DF15D03D 6CA225BC C732F049 7B6DF230 669BD914 5DB60FA5 6C5B926B' 00:00:38 UTC Mon Mar 1 1993
CMD: '86B41304 8763F57D 69AE2262 6C767292 9AF3055E 6633E597 20E00D79 346F311D' 00:00:38 UTC Mon Mar 1 1993
CMD: '585ECDE0 25C1C3A5 DD10DCCE 7E95F6DB 44A75DC6 7192CFA1 81FAF08D E9A6D992' 00:00:38 UTC Mon Mar 1 1993
CMD: 'C3E4F0AD DB6CAFEE ADDA8B09 4AFBDA2A 9E981650 077F87' 00:00:38 UTC Mon Mar 1 1993
CMD: 'end' 00:00:38 UTC Mon Mar 1 1993lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:38.315: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:38.315: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:00:39.371: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:39.371: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:39.371: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 00:00:40.275: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
*Mar 1 00:00:44.331: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-16)
*Mar 1 00:00:44.331: DPAA Initialization Complete
*Mar 1 00:00:44.331: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:44.619: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:50.043: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.80.9.3, mask 255.255.255.0, hostname AP188b.9d5c.dec0
*Mar 1 00:00:56.315: Currently running a Release Image
*Mar 1 00:00:56.335: Using SHA-2 signed certificate for image signing validation.
*Mar 1 00:01:04.243: AP image integrity check PASSED
CMD: 'line vty 0 15' 00:01:04 UTC Mon Mar 1 1993
CMD: ' no transport input' 00:01:04 UTC Mon Mar 1 1993
CMD: 'exit' 00:01:04 UTC Mon Mar 1 1993
CMD: 'end' 00:01:04 UTC Mon Mar 1 1993
CMD: ' no transport input ' 00:01:04 UTC Mon Mar 1 1993
*Mar 1 00:01:04.251: Non-recovery image. PNP Not required.
CMD: 'eap profile lwapp_eap_profile' 00:01:04 UTC Mon Mar 1 1993
CMD: 'method fast' 00:01:04 UTC Mon Mar 1 1993
CMD: 'no dot1x credentials lwapp_credentials' 00:01:04 UTC Mon Mar 1 1993
CMD: 'interface GigabitEthernet0' 00:01:04 UTC Mon Mar 1 1993
CMD: 'no dot1x supplicant eap profile lwapp_eap_profile' 00:01:04 UTC Mon Mar 1 1993
*Mar 1 00:01:04.259: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
CMD: 'ip routing' 00:01:04 UTC Mon Mar 1 1993
CMD: 'ip cef' 00:01:04 UTC Mon Mar 1 1993
CMD: 'no ip routing' 00:01:04 UTC Mon Mar 1 1993
CMD: 'bridge irb' 00:01:04 UTC Mon Mar 1 1993
CMD: 'bridge 1 route ip' 00:01:04 UTC Mon Mar 1 1993
CMD: 'bridge 1 protocol ieee' 00:01:04 UTC Mon Mar 1 1993
CMD: 'int gig1' 00:01:04 UTC Mon Mar 1 1993
CMD: 'bridge-group 1' 00:01:04 UTC Mon Mar 1 1993
CMD: 'bridge-group 1 source-learning' 00:01:04 UTC Mon Mar 1 1993
CMD: 'ip route 0.0.0.0 0.0.0.0 bvi1' 00:01:04 UTC Mon Mar 1 1993
*Mar 1 00:01:04.283: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:01:04.283: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:01:05.307: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Mar 1 00:01:05.307: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface reset
*Mar 1 00:01:05.307: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar 1 00:01:06.415: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:07.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:07.679: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:08.679: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
CMD: 'parser view capwap-config-view' 00:01:14 UTC Mon Mar 1 1993
CMD: PASSWORD statement not printed
CMD: 'end' 00:01:14 UTC Mon Mar 1 1993
CMD: 'commands exec include configure terminal' 00:01:14 UTC Mon Mar 1 1993
CMD: 'commands exec include all show capwap' 00:01:14 UTC Mon Mar 1 1993
CMD: 'commands exec include all enable' 00:01:14 UTC Mon Mar 1 1993
CMD: 'commands configure include all capwap' 00:01:14 UTC Mon Mar 1 1993
CMD: 'commands exec include show running-config' 00:01:14 UTC Mon Mar 1 1993
CMD: 'capwap ap unencrypted_data_keep_alive enable' 00:01:14 UTC Mon Mar 1 1993
CMD: 'capwap ap ble-adv-power 0' 00:01:14 UTC Mon Mar 1 1993
CMD: 'end' 00:01:14 UTC Mon Mar 1 1993creating PnP template view
CMD: 'parser view pnp-config-view' 00:01:14 UTC Mon Mar 1 1993
CMD: 'commands configure include-exclusive capwap ap flexgroup' 00:01:14 UTC Mon Mar 1 1993
*Mar 1 00:01:14.295: Logging LWAPP message to 255.255.255.255.
CMD: 'service timestamps log datetime msec' 00:01:14 UTC Mon Mar 1 1993
CMD: 'logging origin-id string AP:188b.9d5c.dec0' 00:01:14 UTC Mon Mar 1 1993
CMD: 'logging 255.255.255.255' 00:01:14 UTC Mon Mar 1 1993
*Mar 1 00:01:14.299: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
CMD: 'no logging count' 00:01:14 UTC Mon Mar 1 1993
CMD: 'logging on' 00:01:14 UTC Mon Mar 1 1993
*Mar 1 00:01:15.299: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 started - CLI initiated
CMD: 'no ip route 0.0.0.0 0.0.0.0' 00:01:24 UTC Mon Mar 1 1993
CMD: 'end' 00:01:24 UTC Mon Mar 1 1993
*Mar 1 00:01:36.319: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*May 8 18:35:23.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.80.9.1 peer_port: 5246
*May 8 18:35:23.411: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.80.9.1 peer_port: 5246
*May 8 18:35:23.415: %CAPWAP-5-SENDJOIN: sending Join Request to 10.80.9.1
CMD: 'logging facility kern' 18:35:23 UTC Tue May 8 2018
CMD: 'end' 18:35:23 UTC Tue May 8 2018
CMD: 'logging facility kern' 18:35:24 UTC Tue May 8 2018
CMD: 'end' 18:35:24 UTC Tue May 8 2018
*May 8 18:35:24.119: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to channel change from 6 to 6
*May 8 18:35:24.123: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 8 18:35:24.131: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 8 18:35:24.751: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to channel change from 36 to 36
*May 8 18:35:24.751: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*May 8 18:35:24.759: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller M_WLC
*May 8 18:35:24.767: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
CMD: 'line vty 0 15' 18:35:24 UTC Tue May 8 2018
CMD: ' no transport input' 18:35:24 UTC Tue May 8 2018
CMD: 'exit' 18:35:24 UTC Tue May 8 2018
CMD: ' no transport input ' 18:35:24 UTC Tue May 8 2018
*May 8 18:35:24.787: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
CMD: 'logging trap informational' 18:35:24 UTC Tue May 8 2018
CMD: 'no ip nat log translation syslog' 18:35:24 UTC Tue May 8 2018
*May 8 18:35:25.123: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 8 18:35:25.159: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*May 8 18:35:25.167: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*May 8 18:35:25.767: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*May 8 18:35:25.815: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*May 8 18:35:26.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 8 18:35:26.203: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*May 8 18:35:26.211: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 8 18:35:26.219: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 8 18:35:27.203: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*May 8 18:35:27.211: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 8 18:35:27.239: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 8 18:35:28.239: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 8 18:35:47.687: %CLEANAIR-6-STATE: Slot 0 enabled
*May 8 18:35:49.459: %CLEANAIR-6-STATE: Slot 1 enabled
*May 8 18:35:51.687: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*May 8 18:38:21.443: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 19:17:34.511: Writing //AP188b.9d5c.dec0M_WLC08052018_191734.pcap
*May 8 19:20:37.711: Writing //AP188b.9d5c.dec0M_WLC08052018_192037.pcap
*May 8 19:23:41.623: Writing //AP188b.9d5c.dec0M_WLC08052018_192341.pcap
*May 8 19:31:57.487: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 3 AES-CCMP TSC replays
*May 8 19:35:44.739: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 19:41:57.459: Writing //AP188b.9d5c.dec0M_WLC08052018_194157.pcap
*May 8 19:44:00.443: Writing //AP188b.9d5c.dec0M_WLC08052018_194400.pcap
*May 8 19:44:18.519: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 20:03:17.071: Writing //AP188b.9d5c.dec0M_WLC08052018_200317.pcap
*May 8 20:33:42.659: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 5 AES-CCMP TSC replays
*May 8 20:43:50.499: Writing //AP188b.9d5c.dec0M_WLC08052018_204350.pcap
*May 8 20:46:53.175: Writing //AP188b.9d5c.dec0M_WLC08052018_204653.pcap
*May 8 20:49:34.783: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 8 20:49:55.715: Writing //AP188b.9d5c.dec0M_WLC08052018_204955.pcap
*May 8 21:10:11.735: Writing //AP188b.9d5c.dec0M_WLC08052018_211011.pcap
*May 8 21:13:14.367: Writing //AP188b.9d5c.dec0M_WLC08052018_211314.pcap
*May 8 21:21:18.955: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 21:33:30.055: Writing //AP188b.9d5c.dec0M_WLC08052018_213330.pcap
*May 8 21:42:35.111: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 21:46:40.059: Writing //AP188b.9d5c.dec0M_WLC08052018_214640.pcap
*May 8 21:51:36.155: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 22:12:00.679: Writing //AP188b.9d5c.dec0M_WLC08052018_221200.pcap
*May 8 22:16:03.919: Writing //AP188b.9d5c.dec0M_WLC08052018_221603.pcap
*May 8 22:20:06.535: Writing //AP188b.9d5c.dec0M_WLC08052018_222006.pcap
*May 8 22:21:49.475: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 22:23:02.475: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 22:31:58.535: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 8 22:35:00.591: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 22:41:23.567: Writing //AP188b.9d5c.dec0M_WLC08052018_224123.pcap
*May 8 22:44:25.991: Writing //AP188b.9d5c.dec0M_WLC08052018_224425.pcap
*May 8 22:53:22.583: %DOT11-4-CCMP_REPLAY: Client 9465.2d6f.a592 had 1 AES-CCMP TSC replays
*May 8 23:04:41.831: Writing //AP188b.9d5c.dec0M_WLC08052018_230441.pcap
*May 8 23:14:15.927: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 23:17:50.731: Writing //AP188b.9d5c.dec0M_WLC08052018_231750.pcap
*May 8 23:31:46.059: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 6 AES-CCMP TSC replays
*May 8 23:36:28.103: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 8 23:44:12.071: Writing //AP188b.9d5c.dec0M_WLC08052018_234412.pcap
*May 8 23:47:14.519: Writing //AP188b.9d5c.dec0M_WLC08052018_234714.pcap
*May 8 23:51:17.359: Writing //AP188b.9d5c.dec0M_WLC08052018_235117.pcap
*May 8 23:59:19.631: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 00:03:41.295: %DOT11-4-CCMP_REPLAY: Client 9465.2d6f.a592 had 2 AES-CCMP TSC replays
*May 9 00:04:09.311: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 00:13:34.419: Writing //AP188b.9d5c.dec0M_WLC09052018_001334.pcap
*May 9 00:15:18.887: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 00:16:37.035: Writing //AP188b.9d5c.dec0M_WLC09052018_001637.pcap
*May 9 00:29:55.511: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 5 AES-CCMP TSC replays
*May 9 00:35:53.055: Writing //AP188b.9d5c.dec0M_WLC09052018_003553.pcap
*May 9 00:47:12.871: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 00:48:00.895: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 00:48:06.795: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 6 AES-CCMP TSC replays
*May 9 00:48:16.795: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 00:49:13.675: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 00:49:44.675: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 00:50:02.527: Writing //AP188b.9d5c.dec0M_WLC09052018_005002.pcap
*May 9 00:50:11.675: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 00:51:00.707: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 00:52:00.707: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 00:52:13.707: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 00:52:49.711: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 4 AES-CCMP TSC replays
*May 9 00:53:08.711: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 6 AES-CCMP TSC replays
*May 9 00:55:39.711: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 00:55:45.711: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 7 AES-CCMP TSC replays
*May 9 00:56:48.347: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 01:16:22.595: Writing //AP188b.9d5c.dec0M_WLC09052018_011622.pcap
*May 9 01:19:25.175: Writing //AP188b.9d5c.dec0M_WLC09052018_011925.pcap
*May 9 01:23:28.395: Writing //AP188b.9d5c.dec0M_WLC09052018_012328.pcap
*May 9 01:42:42.759: Writing //AP188b.9d5c.dec0M_WLC09052018_014242.pcap
*May 9 01:45:46.167: Writing //AP188b.9d5c.dec0M_WLC09052018_014546.pcap
*May 9 01:53:20.147: %DOT11-4-CCMP_REPLAY: Client 9465.2d6f.a592 had 1 AES-CCMP TSC replays
*May 9 02:04:00.391: Writing //AP188b.9d5c.dec0M_WLC09052018_020400.pcap
*May 9 02:07:37.251: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 02:17:09.967: Writing //AP188b.9d5c.dec0M_WLC09052018_021709.pcap
*May 9 02:33:07.491: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 7 AES-CCMP TSC replays
*May 9 02:44:16.627: Writing //AP188b.9d5c.dec0M_WLC09052018_024416.pcap
*May 9 02:53:32.643: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 03:17:47.791: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 03:26:50.307: Writing //AP188b.9d5c.dec0M_WLC09052018_032650.pcap
*May 9 03:34:15.887: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 03:34:23.887: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 03:37:59.623: Writing //AP188b.9d5c.dec0M_WLC09052018_033759.pcap
*May 9 03:42:02.447: Writing //AP188b.9d5c.dec0M_WLC09052018_034202.pcap
*May 9 03:54:11.787: Writing //AP188b.9d5c.dec0M_WLC09052018_035411.pcap
*May 9 03:55:35.087: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 03:59:15.779: Writing //AP188b.9d5c.dec0M_WLC09052018_035915.pcap
*May 9 04:08:23.291: Writing //AP188b.9d5c.dec0M_WLC09052018_040823.pcap
*May 9 04:30:59.347: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 3 AES-CCMP TSC replays
*May 9 05:03:59.583: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 05:09:17.107: Writing //AP188b.9d5c.dec0M_WLC09052018_050917.pcap
*May 9 05:17:23.995: Writing //AP188b.9d5c.dec0M_WLC09052018_051723.pcap
*May 9 05:27:36.415: Writing //AP188b.9d5c.dec0M_WLC09052018_052736.pcap
*May 9 05:32:33.787: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 05:32:36.871: Writing //AP188b.9d5c.dec0M_WLC09052018_053236.pcap
*May 9 05:38:42.035: Writing //AP188b.9d5c.dec0M_WLC09052018_053842.pcap
*May 9 05:50:52.499: Writing //AP188b.9d5c.dec0M_WLC09052018_055052.pcap
*May 9 06:10:11.023: Writing //AP188b.9d5c.dec0M_WLC09052018_061011.pcap
*May 9 06:13:29.999: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 06:13:48.999: %DOT11-4-CCMP_REPLAY: Client 1865.90df.1c3f had 1 AES-CCMP TSC replays
*May 9 06:14:51.999: %DOT11-4-CCMP_REPLAY: Client 1865.90df.1c3f had 1 AES-CCMP TSC replays
*May 9 06:18:37.511: %DOT11-4-CCMP_REPLAY: Client 1865.90df.1c3f had 1 AES-CCMP TSC replays
*May 9 06:23:37.795: %DOT11-4-CCMP_REPLAY: Client 1865.90df.1c3f had 1 AES-CCMP TSC replays
*May 9 06:34:04.175: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 6 AES-CCMP TSC replays
*May 9 06:34:38.175: %DOT11-4-CCMP_REPLAY: Client 8c85.9026.4648 had 1 AES-CCMP TSC replays
*May 9 06:41:44.831: %DOT11-4-CCMP_REPLAY: Client 8c85.9026.4648 had 1 AES-CCMP TSC replays
*May 9 07:01:04.311: Writing //AP188b.9d5c.dec0M_WLC09052018_070104.pcap
*May 9 07:03:05.639: Writing //AP188b.9d5c.dec0M_WLC09052018_070305.pcap
*May 9 07:07:08.995: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 07:09:14.623: Writing //AP188b.9d5c.dec0M_WLC09052018_070914.pcap
*May 9 07:15:20.831: Writing //AP188b.9d5c.dec0M_WLC09052018_071520.pcap
*May 9 07:16:56.355: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 07:17:49.387: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 07:21:13.739: %DOT11-4-CCMP_REPLAY: Client c4b3.01c3.34cb had 1 AES-CCMP TSC replays
*May 9 07:22:29.003: Writing //AP188b.9d5c.dec0M_WLC09052018_072229.pcap
*May 9 07:30:18.451: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 07:31:41.347: Writing //AP188b.9d5c.dec0M_WLC09052018_073141.pcap
*May 9 07:33:42.195: Writing //AP188b.9d5c.dec0M_WLC09052018_073342.pcap
*May 9 07:35:44.675: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 07:49:49.559: Writing //AP188b.9d5c.dec0M_WLC09052018_074949.pcap
*May 9 07:50:04.827: Writing //AP188b.9d5c.dec0M_WLC09052018_075004.pcap
*May 9 07:50:44.515: %DOT11-4-CCMP_REPLAY: Client c4b3.01c7.bff5 had 1 AES-CCMP TSC replays
*May 9 07:56:22.007: %DOT11-4-CCMP_REPLAY: Client c4b3.01c7.bff5 had 1 AES-CCMP TSC replays
*May 9 07:58:29.347: %DOT11-4-CCMP_REPLAY: Client 04d6.aaba.b8a8 had 20 AES-CCMP TSC replays
*May 9 08:07:25.627: Writing //AP188b.9d5c.dec0M_WLC09052018_080725.pcap
*May 9 08:16:37.779: Writing //AP188b.9d5c.dec0M_WLC09052018_081637.pcap
*May 9 08:22:44.823: Writing //AP188b.9d5c.dec0M_WLC09052018_082244.pcap
*May 9 08:30:51.699: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 08:32:42.699: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 11 AES-CCMP TSC replays
*May 9 08:35:02.915: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 43 AES-CCMP TSC replays
*May 9 08:35:12.915: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 228 AES-CCMP TSC replays
*May 9 08:36:13.915: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 38 AES-CCMP TSC replays
*May 9 08:36:30.915: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 34 AES-CCMP TSC replays
*May 9 08:36:43.915: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 29 AES-CCMP TSC replays
*May 9 08:37:19.915: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 4 AES-CCMP TSC replays
*May 9 08:41:28.947: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 08:46:00.975: %DOT11-4-CCMP_REPLAY: Client 6c96.cfde.0b2b had 1 AES-CCMP TSC replays
*May 9 08:48:50.803: %DOT11-4-BAD_BASSN: Client 6c96.cfde.0b2b(40145) DELBA upstream for priority 0 on packet seq jump
*May 9 08:49:18.775: Writing //AP188b.9d5c.dec0M_WLC09052018_084918.pcap
*May 9 08:50:19.487: Writing //AP188b.9d5c.dec0M_WLC09052018_085019.pcap
*May 9 08:59:46.487: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 09:00:55.115: Writing //AP188b.9d5c.dec0M_WLC09052018_090055.pcap
*May 9 09:01:02.499: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 09:06:42.083: Writing //AP188b.9d5c.dec0M_WLC09052018_090642.pcap
*May 9 09:31:57.055: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 6 AES-CCMP TSC replays
*May 9 09:33:54.375: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 09:35:11.715: Writing //AP188b.9d5c.dec0M_WLC09052018_093511.pcap
*May 9 09:44:00.487: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 10:00:57.555: %DOT11-4-CCMP_REPLAY: Client 9801.a7ad.5e13 had 1 AES-CCMP TSC replays
*May 9 10:04:53.875: Writing //AP188b.9d5c.dec0M_WLC09052018_100453.pcap
*May 9 10:07:58.651: Writing //AP188b.9d5c.dec0M_WLC09052018_100758.pcap
*May 9 10:11:52.603: %DOT11-4-CCMP_REPLAY: Client 3007.4dad.c258 had 3 AES-CCMP TSC replays
*May 9 10:15:56.631: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 1 AES-CCMP TSC replays
*May 9 10:17:58.655: %DOT11-4-CCMP_REPLAY: Client bc92.6b12.eb08 had 1 AES-CCMP TSC replays
*May 9 10:25:18.859: Writing //AP188b.9d5c.dec0M_WLC09052018_102518.pcap
*May 9 10:27:20.431: Writing //AP188b.9d5c.dec0M_WLC09052018_102720.pcap
*May 9 10:28:24.283: Writing //AP188b.9d5c.dec0M_WLC09052018_102824.pcap
*May 9 10:29:44.267: %DOT11-4-CCMP_REPLAY: Client acbc.3288.28a9 had 1 AES-CCMP TSC replays
*May 9 10:30:24.287: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 11 AES-CCMP TSC replays
*May 9 10:30:25.667: Writing //AP188b.9d5c.dec0M_WLC09052018_103025.pcap
*May 9 10:34:32.591: Writing //AP188b.9d5c.dec0M_WLC09052018_103432.pcap
*May 9 10:37:57.779: %DOT11-4-CCMP_REPLAY: Client cc9f.7a9d.468f had 2 AES-CCMP TSC replays
*May 9 10:40:39.515: Writing //AP188b.9d5c.dec0M_WLC09052018_104039.pcap
*May 9 10:42:23.047: Writing //AP188b.9d5c.dec0M_WLC09052018_104223.pcap
*May 9 10:42:41.443: Writing //AP188b.9d5c.dec0M_WLC09052018_104241.pcap
*May 9 10:51:02.875: %DOT11-4-CCMP_REPLAY: Client a45e.60d5.ef49 had 1 AES-CCMP TSC replays
*May 9 10:53:12.071: Writing //AP188b.9d5c.dec0M_WLC09052018_105312.pcap
*May 9 11:02:19.947: %DOT11-4-CCMP_REPLAY: Client 4098.ada1.6489 had 3 AES-CCMP TSC replays
*May 9 11:13:19.883: Writing //AP188b.9d5c.dec0M_WLC09052018_111319.pcap
*May 9 11:20:31.391: Writing //AP188b.9d5c.dec0M_WLC09052018_112031.pcap
*May 9 11:22:32.747: Writing //AP188b.9d5c.dec0M_WLC09052018_112232.pcap
CPU Register Context:
MSR = 0x00029200 CR = 0x48002048 CTR = 0x02C5C684 XER = 0x00000000
R0 = 0x032CF9E0 R1 = 0x066EF2F0 R2 = 0x00010001 R3 = 0x0516AE54
R4 = 0x091E8A64 R5 = 0x067723BC R6 = 0x0000FFFF R7 = 0x0000FFFE
R8 = 0x00000001 R9 = 0xE60657DA R10 = 0x00021200 R11 = 0x032CF9E0
R12 = 0x00000000 R13 = 0x87298606 R14 = 0x03CF0000 R15 = 0xE142349A
R16 = 0x03D20000 R17 = 0x04710000 R18 = 0x04710000 R19 = 0x03808808
R20 = 0x047709D8 R21 = 0x04710000 R22 = 0x00000000 R23 = 0x04710000
R24 = 0x04710000 R25 = 0x00000001 R26 = 0x0000002E R27 = 0x00000001
R28 = 0x1E30CE5A R29 = 0x00000006 R30 = 0x0516AE54 R31 = 0x091E8A64
TEXT_START : 0x01003000
DATA_START : 0x03000000
MCSRR0: 0x00000000, MCSRR1: 0x00000000 MCSR: 0x00000000 MCAR: 0x00000000
Total PCI 0 MC Error = 0; PCI LD count=0
Total PCI 1 MC Error = 0; PCI LD count=0
Total PCI 2 MC Error = 0; PCI LD count=0
=== Start of Crashinfo Collection (11:23:17 UTC Wed May 9 2018) ===
For image:
Cisco IOS Software, C1700 Software (AP3G2-K9W8-M), Version 15.3(3)JD14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 23-Mar-18 09:21 by prod_rel_team
System image file is: flash:/ap3g2-k9w8-mx.153-3.JD14/ap3g2-k9w8-xx.153-3.JD14
========= Show Alignment =============================
No alignment data has been recorded.
No spurious memory references have been recorded.
========== Stack Trace========
========= Context ======================
Signal = 11, Vector = 1400
MSR: 0x00021200 SRR0 = 0x01465160 SRR1 = 0x00021200 DEAR = 0xE60657E2
PC = 0x012D25F8 MSR = 0x00029200 CR = 0x48002048 LR = 0x0125BEFC
CTR = 0x02C5C684 XER = 0x00000000 DAR = 0xE60657E2 DSISR = 0x400F0000
DEC = 0x00000000 TBU = 0x00000234 TBL = 0x1EBDCEAA IMMR = 0x00000000
========= Stack Dump ==========================
Stack Frame Pointer in Context is 0x66EF2F0 , at interrupt level 4
66EEEF0: 66EEF28 400 FBF80 9C69A64 66EEF38 40A4 FBF80 9C69A64
66EEF10: D9EF2A0 40A4 1E27EEB0 400839 88 A3B563C 0 66EEF48
66EEF30: 9AD6218 0 66EF018 188FEB4 40000 400 66EEF80 0
66EEF50: FBF80 9C69A64 D9DF26C 40A4 1E7881B0 4008B9 88 A3CFFDC
66EEF70: 0 66EEF90 9AD6218 1 66EF060 1890300 40000 400
66EEF90: D7 161 15F 15C 200 4CBC 800000 66EEFB8
66EEFB0: 187AC48 2605421E 66EEFF0 2600421E 0 9C69A64 0 4080
66EEFD0: 1E2C6ED2 640030 66EF000 A3A181C 1 640030 9AD6218 1
66EEFF0: 66EF0D0 1890254 40000 400 8 0 0 0
66EF010: 6900 4180 800300 A3A181C 9021E 0 0 0
66EF030: 750000 1167AA94 1 0 4991F78 18 9C69A64 9C69A64
66EF050: 66EF088 1FEA3F0 66EF068 5AF2DA06 40D34F6 A3A4B5C 2 B
66EF070: 2 100000 42 8 CD7347C 24422042 33D3EE4 33D2480
66EF090: 4710000 4710000 66EF100 33D3F18 0 0 0 0
66EF0B0: A 22424024 0 1E2C6F0A 9D59A64 9AD541C 66EF100 8
66EF0D0: FBF80 9C69A64 D9F58D8 40A4 1E6D4730 400831 88 A3A181C
66EF0F0: 0 66EF110 9AD6218 0 66EF1E0 188FEB4 40000 400
66EF110: 0 0 0 0 100 4CA4 0 A3A8BBC
66EF130: 6216422E 2214421E 2605421E 2603421E 80004900 4710000 0 1
66EF150: 0 9C69A64 66EF168 10 40 9137F9C 66EF180 1538DE4
66EF170: 1F 29200 2 0 1 100300 42 8
66EF190: BE9A388 24444042 33D3EE4 33D2480 66EF1D8 4710000 33D3F10 33D3F18
66EF1B0: 0 0 1 1F3 314340 5 4C33B5C 1E28D9F9
66EF1D0: 0 91AEE10 66EF218 2E4AD0C FF030000 1E28D9E9 1F30008A 50000000
66EF1F0: C3 0 0 210000 7A 4 8A 91AEE10
66EF210: 4 67723BC 66EF238 153A1A8 0 0 1E28DBE4 C3210000
66EF230: 1E28DBEC 91AEE10 66EF240 1B755CC 66EF248 1B75748 66EF250 1B5F5E8
66EF250: 66EF2B8 1B77350 0 91AEE10 1 0 0 4
66EF270: 0 3A5D491C A3A8BBC 0 1 24442042 0 380
66EF290: 66EF298 9AD541C 66EF2A8 1B2AE84 1E28DBDE 91E8A64 66EF398 1B7D134
66EF2B0: 1040000 A500901 0 0 0 0 0 0
66EF2D0: 4 250 9C69A64 927001C 7F3E274D 186590DE A617AE54 91456CC
66EF2F0: 66EF300 12D263C 91E8A64 91E8A64 66EF310 125BEFC 66EF320 91E8A64
66EF310: 66EF320 2C5C6E4 91E8A64 A4B71EC 66EF370 2C5ECB8 66EF330 1E24C580
66EF330: 104F358 A500903 66EF360 99BC874 0 0 1 100300
66EF350: 4A 66EF378 47CDEE0 1 1E30CE4C 7 67723BC 91E8A64
66EF370: 66EF388 12E2180 1E30CE4C 22219C4 66EF388 91E8A64 66EF3B0 1D77BFC
66EF390: 67723BC 1 47CDEE0 1E30CE4C 67723BC 0 91E8A64 1B
66EF3B0: 66EF410 1D7ADEC 6E0000 18551F8 0 9AD541C 44004082 9D59A64
66EF3D0: 88 9C79A64 24002022 3808808 47709D8 1E 0 3C
66EF3F0: 1D7A5B4 1E30CE4C 47CDEE0 0 0 0 67723BC 91E8A64
66EF410: 66EF458 153AB38 5E3D3F80 243F0604 80959A13 24002028 3CF0000 476E328
66EF430: 4767870 66EF498 91E8A64 3C 67723BC 1E30CE4C 0 80000028
66EF450: 45942D0 0 66EF490 2E4B098 1E 26 91AEE10 1EBDCB65
66EF470: 579DE9C 66EF498 3C 2E4AEF0 3237C0 1E30CE0C 0 FF001050
66EF490: 66EF4E8 2E5D6BC 0 579DE9C 0 BE9A3FC 400000 0
66EF4B0: 0 0 0 FF001050 66EF518 476E328 476F5F0 FFFF
66EF4D0: 4720000 0 3F 579DE9C FF001040 1A4840 66EF510 2E57A28
66EF4F0: 4767870 44002024 4710000 3D20F94 0 3808868 20000 579DE9C
66EF510: 66EF520 2E56E98 21200 47708D0 47708D0 1465418 FFFFFFFF FFFFFFFF
66EF530: FFFFFFFF FD0110DF AB1234CD FFFE0000 0 32602D8 1E08D10 66F91AC
66EF550: 66E6878 80004E22 1 0 1000001 519B9D0 0 64BE8F4
66EF570: 64BE8D4 64BE8B4 64BE894 64BE874 64BE854 64BE834 64BE814 0
66EF590: 0 0 0 0 0 0 0 0
66EF5B0: 0 0 0 0 0 0 0 0
66EF5D0: 0 0 0 0 0 0 0 0
66EF5F0: 0 0 0 0 0 0 0 0
66EF610: 0 0 0 0 0 0 0 0
66EF630: 0 0 0 0 0 0 0 0
66EF650: 0 0 0 0 0 0 0 0
66EF670: 0 0 0 0 0 0 0 0
66EF690: 0 0 0 0 0 0 0 0
66EF6B0: 0 0 0 0 0 0 0 0
66EF6D0: 0 0 0 0 0 0 0 0
========= Process Level Info ==================
---- Current Process Block (at 0xB5C0504) ----
B5C04D4: AB1234CD A30000 A6 35E572C 12D4374 B5C0838 B5BD5D4 8000019A
B5C04F4: 1 0 10000AD 9B61030 B5BD5F0 B5C0488 0 26CE9B0
B5C0514: 0 0 0 0 0 0 0 0
B5C0534: 0 0 0 0 0 0 0 3810000
B5C0554: 8 20000042 12D2B54 29200 0 0 0 26CE9B0
B5C0574: 0 10000 1 0 0 0 0 6
B5C0594: A3 26CE9DC 12D2AEC 0 0 0 3368 0
B5C05B4: 0 0 A6 0 0 39C42EC 0 0
B5C05D4: 0 39C42EC 0 39C42EC 98 0 1D BE0FAD4
B5C05F4: 72DE21 0 365CBF0 4 0 0 0 0
B5C0614: 0 0 2EE0 2EE0 516B9B0 0 0 0
B5C0634: 0 0 0 0 A4B8078 B5C0504 47555C4 0
B5C0654: 677207C 4755780 3D125A8 B5C06D4 0 0 0 39C42F4
B5C0674: 420E 0 0 0 B5C0654 0 0 0
B5C0694: 0 0 4290 0 B5C0504 0 0 0
B5C06B4: B5C0654 B5C0504 0 0 0 0 142D2 0
B5C06D4: 0 B5C06D4 B5C0654 B5C0504 0 0 0 39C42F4
B5C06F4: 242D6 0 0 0 0 0 0 B5C0868
B5C0714: 0 0 0 0 0 0 0 0
B5C0734: 0 B5C08FC B5C0724 B5C0870 0 474B880 0 0
B5C0754: 0 0 0 1 FFFFFFF 0 0 0
B5C0774: 0 0 0 0 0 0 0 0
B5C0794: 0 0 0 B5C0958 0 0 32 0
B5C07B4: 0 0 0 0 0 898C B0B482C B0B482C
B5C07D4: 9B61070 B5C0878 B5C07CC 3D0D010 A9F D0000 1 0
B5C07F4: 32E5D80 12CA308 12CA310 380238C 0 9B61030 0 10000AD
B5C0814: 0 0 0 0 0 0 BEEFCAFE 0
---- Partial decode of process block ----
Pid 163: Process "NBAR timer tick task "
stack 0xB5BD5F0 savedsp 0xB5C0488
Flags: analyze prefers_new
Status 0x00000000 Orig_ra 0x00000000 Routine 0x026CE9B0 Signal 0
Caller_pc 0x026CE9DC Callee_pc 0x012D2AEC Dbg_events 0x00000000 State 6
Totmalloc 0 Totfree 0 Totgetbuf 0
Totretbuf 0 Edisms 0x0 Eparm 0x0
Elapsed 0x98 Ncalls 0x72DE21 Ngiveups 0x0
Priority_q 4 Ticks_5s 0 Cpu_5sec 0 Cpu_1min 0
Cpu_5min 0 Stacksize 0x2EE0 Lowstack 0x2EE0
Ttyptr 0x516B9B0 Mem_holding 0x3368 Thrash_count 0
Wakeup_reasons 0x00000001 Default_wakeup_reasons 0x0FFFFFFF
Direct_wakeup_major 0x00000000 Direct_wakeup_minor 0x00000000
Regs R14-R31, CR, PC, MSR at last suspend; R3 from proc creation, PC unused:
R3 : 00000000 R14: 026CE9B0 R15: 00000000 R16: 00000000 R17: 00000000
R18: 00000000 R19: 00000000 R20: 00000000 R21: 00000000 R22: 00000000
R23: 00000000 R24: 00000000 R25: 00000000 R26: 00000000 R27: 00000000
R28: 00000000 R29: 00000000 R30: 03810000 R31: 00000008 CR: 20000042
PC : 012D2B54 MSR: 00029200
---- Current Process Stack (0x15C bytes used, out of 0x2EE0 available) ----
Current SP = 0x66EF2F0 , saved SP = 0xB5C0488
B5C0374: B5C0380 132C30C FFFFFFFF B5C0398 B5C0390 2EC6980 B5C0398 B5C0398
B5C0394: B5C03A0 B5C03B8 26CBDD8 0 39BB9D8 0 39BB9D8 B5C03C8
B5C03B4: 26CCCC0 B5C03D0 26CCD9C 0 415E7F0 B5C03F8 26CD13C B5C03D8
B5C03D4: 0 B5C03E0 26CF734 B5C03F8 26CCE10 39BB910 415E890 0
B5C03F4: 39BAC90 B5C0448 2704CC0 B5C0418 0 0 0 B5C0418
B5C0414: 0 B5C0458 2C52CD4 0 39C42F4 0 39C42F6 B5C0468
B5C0434: 20000042 0 0 0 B5C06D4 B5C0468 8 3810000
B5C0454: 8 B5C0488 2C538B4 12D2B34 3808A04 0 39C42F4 B5C0488
B5C0474: 0 0 B5C0488 145FA1C 8 B5C04B0 12D2B48 26CE9DC
B5C0494: 0 4145934 0 0 0 0 4140000 B5C04C0
B5C04B4: 26CE9E0 FFFFFFFF 0 B5C04C8 1347D30 0 132EABC
========= Interrupt Level Stack Dump ==========
---- Level 1 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[1]: base 0x0 stack 0x0 routine 0x0 count 0x0
size 0x0 low 0x0 desc 0x0
---- Level 2 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[2]: base 0x0 stack 0x0 routine 0x0 count 0x0
---- Level 3 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[3]: base 0x0 stack 0x0 routine 0x0 count 0x0
---- Level 4 Interrupt stack (0x64C bytes used, out of 0x2328 available) ----
intstacks[4]: base 0x66ED20C stack 0x66EF528 routine 0x0 count 0x5171E35
size 0x2328 low 0x2328 desc 0x3326710
66EF134: 2214421E 2605421E 2603421E 80004900 4710000 0 1 0
66EF154: 9C69A64 66EF168 10 40 9137F9C 66EF180 1538DE4 1F
66EF174: 29200 2 0 1 100300 42 8 BE9A388
66EF194: 24444042 33D3EE4 33D2480 66EF1D8 4710000 33D3F10 33D3F18 0
66EF1B4: 0 1 1F3 314340 5 4C33B5C 1E28D9F9 0
66EF1D4: 91AEE10 66EF218 2E4AD0C FF030000 1E28D9E9 1F30008A 50000000 C3
66EF1F4: 0 0 210000 7A 4 8A 91AEE10 4
66EF214: 67723BC 66EF238 153A1A8 0 0 1E28DBE4 C3210000 1E28DBEC
66EF234: 91AEE10 66EF240 1B755CC 66EF248 1B75748 66EF250 1B5F5E8 66EF2B8
66EF254: 1B77350 0 91AEE10 1 0 0 4 0
66EF274: 3A5D491C A3A8BBC 0 1 24442042 0 380 66EF298
66EF294: 9AD541C 66EF2A8 1B2AE84 1E28DBDE 91E8A64 66EF398 1B7D134 1040000
66EF2B4: A500901 0 0 0 0 0 0 4
66EF2D4: 250 9C69A64 927001C 7F3E274D 186590DE A617AE54 91456CC 66EF300
66EF2F4: 12D263C 91E8A64 91E8A64 66EF310 125BEFC 66EF320 91E8A64 66EF320
66EF314: 2C5C6E4 91E8A64 A4B71EC 66EF370 2C5ECB8 66EF330 1E24C580 104F358
66EF334: A500903 66EF360 99BC874 0 0 1 100300 4A
66EF354: 66EF378 47CDEE0 1 1E30CE4C 7 67723BC 91E8A64 66EF388
66EF374: 12E2180 1E30CE4C 22219C4 66EF388 91E8A64 66EF3B0 1D77BFC 67723BC
66EF394: 1 47CDEE0 1E30CE4C 67723BC 0 91E8A64 1B 66EF410
66EF3B4: 1D7ADEC 6E0000 18551F8 0 9AD541C 44004082 9D59A64 88
66EF3D4: 9C79A64 24002022 3808808 47709D8 1E 0 3C 1D7A5B4
66EF3F4: 1E30CE4C 47CDEE0 0 0 0 67723BC 91E8A64 66EF458
66EF414: 153AB38 5E3D3F80 243F0604 80959A13 24002028 3CF0000 476E328 4767870
66EF434: 66EF498 91E8A64 3C 67723BC 1E30CE4C 0 80000028 45942D0
66EF454: 0 66EF490 2E4B098 1E 26 91AEE10 1EBDCB65 579DE9C
66EF474: 66EF498 3C 2E4AEF0 3237C0 1E30CE0C 0 FF001050 66EF4E8
66EF494: 2E5D6BC 0 579DE9C 0 BE9A3FC 400000 0 0
66EF4B4: 0 0 FF001050 66EF518 476E328 476F5F0 FFFF 4720000
66EF4D4: 0 3F 579DE9C FF001040 1A4840 66EF510 2E57A28 4767870
66EF4F4: 44002024 4710000 3D20F94 0 3808868 20000 579DE9C 66EF520
66EF514: 2E56E98 21200 47708D0 47708D0 1465418 FFFFFFFF FFFFFFFF FFFFFFFF
PC = 0x5E3D3F80 MSR = 0x243F0604 CR = 0x80959A13 LR = 0x24002028
CTR = 0x03CF0000 XER = 0x0476E328 DAR = 0x067723BC DSISR = 0x1E30CE4C
DEC = 0x04767870 TBU = 0x066EF498 TBL = 0x091E8A64 IMMR = 0x00000000
R0 = 0x047CDEE0 R1 = 0x1E30CE4C R2 = 0x067723BC R3 = 0x00000000
R4 = 0x091E8A64 R5 = 0x0000001B R6 = 0x066EF410 R7 = 0x01D7ADEC
R8 = 0x006E0000 R9 = 0x018551F8 R10 = 0x00000000 R11 = 0x09AD541C
R12 = 0x44004082 R13 = 0x09D59A64 R14 = 0x00000088 R15 = 0x09C79A64
R16 = 0x24002022 R17 = 0x03808808 R18 = 0x047709D8 R19 = 0x0000001E
R20 = 0x00000000 R21 = 0x0000003C R22 = 0x01D7A5B4 R23 = 0x1E30CE4C
R24 = 0x047CDEE0 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x00000000
R28 = 0x067723BC R29 = 0x091E8A64 R30 = 0x066EF458 R31 = 0x0153AB38
---- Level 5 Interrupt stack (0x0 bytes used, out of 0x2328 available) ----
intstacks[5]: base 0x66EAEE4 stack 0x66ED200 routine 0x0 count 0x0
size 0x2328 low 0x2328 desc 0x3326678
---- Level 6 Interrupt stack (0x40 bytes used, out of 0x2328 available) ----
intstacks[6]: base 0x66E8BBC stack 0x66EAED8 routine 0x0 count 0x6968
size 0x2328 low 0x2328 desc 0x33266B8
66EAEA4: 66EAEB0 66EAEB0 66EAEB8 66EAEC8 1466888 66EAEC8 38088A8 66EAEC8
66EAEC4: 47708D0 66EAED0 14668D8 47708D0 1465418 FFFFFFFF FFFFFFFF FFFFFFFF
---- Level 7 Interrupt stack (0x6C bytes used, out of 0x2328 available) ----
intstacks[7]: base 0x66E6894 stack 0x66E8BB0 routine 0x0 count 0xE710BB
size 0x2328 low 0x2328 desc 0x3326454
66E8B50: 66E8B68 FFFFFFFF 0 39C4290 0 39C4294 66E8B90 13348E4
66E8B70: 0 39C4290 FFFFFFFF FFFFFFFF 4710000 38088C8 4710000 1
66E8B90: 66E8B98 129D1B8 66E8BA8 145F564 21200 47708D0 47708D0 1465418
66E8BB0: FFFFFFFF FFFFFFFF FFFFFFFF
---- Level 8 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[8]: base 0x0 stack 0x0 routine 0x0 count 0x0
---- Level 9 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[9]: base 0x0 stack 0x0 routine 0x0 count 0x0
========= Register Memory Dump ================
Reg00(PC ): 12D25F8
Reg01(MSR): 29200 [Not RAM Addr]
Reg02(CR ): 48002048 [Not RAM Addr]
Reg03(LR ): 125BEFC
Reg04(CTR): 2C5C684
Reg05(XER): 0
Reg06(DAR): E60657E2 [Not RAM Addr]
Reg07(DSISR): 400F0000 [Not RAM Addr]
Reg08(DEC): 0
Reg09(TBU): 234
Reg10(TBL): 1EBDCEAA [In malloc Block 0x1EBDCD68]
Reg11(IMMR): 0
Reg12(R0 ): 32CF9E0
Reg13(R1 ): 66EF2F0
Reg14(R2 ): 10001 [Not RAM Addr]
Reg15(R3 ): 516AE54
Reg16(R4 ): 91E8A64 [In malloc Block 0x91E8A34] [Last malloc Block 0x91E8550]
Reg17(R5 ): 67723BC [In malloc Block 0x677238C] [Last malloc Block 0x6772308]
Reg18(R6 ): FFFF [Not RAM Addr]
Reg19(R7 ): FFFE [Not RAM Addr]
Reg20(R8 ): 1
Reg21(R9 ): E60657DA [Not RAM Addr]
Reg22(R10): 21200 [Not RAM Addr]
Reg23(R11): 32CF9E0
Reg24(R12): 0
Reg25(R13): 87298606 [Not RAM Addr]
Reg26(R14): 3CF0000
Reg27(R15): E142349A [Not RAM Addr]
Reg28(R16): 3D20000
Reg29(R17): 4710000
Reg30(R18): 4710000
Reg31(R19): 3808808
Reg32(R20): 47709D8
Reg33(R21): 4710000
Reg34(R22): 0
Reg35(R23): 4710000
Reg36(R24): 4710000
Reg37(R25): 1
Reg38(R26): 2E
Reg39(R27): 1
Reg40(R28): 1E30CE5A [In malloc Block 0x1E30CC44]
Reg41(R29): 6
Reg42(R30): 516AE54
Reg43(R31): 91E8A64
---- block0 ptr=66EF290 is_malloc=0 length=0x260 ----
---- block1 ptr=12D25F8 is_malloc=0 length=0x100 ----
12D25B8: 38600000 48000084 8004FFD0 3D20AB12 612934CD 7F804800 3924FFD0 40BE0038
12D25D8: 8169000C 3D200380 8009BE60 7F8B0000 40BE0024 813E0010 2F890000 419E0018
12D25F8: 81690008 7C832378 812B0020 80890304 4BF7F979 813E006C 2F890000 419E0014
12D2618: 801E0068 38600000 7F890000 409D001C 7FE4FB78 387E0060 4BFF4A2D 7FC3F378
12D2638: 4BFFEC05 38600001 80010014 83C10008 83E1000C 38210010 7C0803A6 4E800020
12D2658: 7C6B1B79 38600001 4D820020 812B006C 38600000 2F890000 4D9E0020 800B0068
12D2678: 7F890000 7D200026 5529F7FE 69230001 4E800020 9421FFE8 7C0802A6 93A1000C
12D2698: 7C7D1B79 93810008 93C10010 93E10014 9001001C 41820010 83FD0000 2F9F0000
12D26B8: 40BE0034 3D200471 3C600301 81295E3C 3C800357 3CA0032F 38849664 38A5BD10
12D26D8: 7D2903A6 38C00000 38635C9C 4E800421 4800008C 3D2003CF 8069B054 4818D37D
---- block2 ptr=125BEFC is_malloc=0 length=0x100 ----
125BEBC: 41820010 7FE3FB78 7C0903A6 4E800421 8001001C 83A1000C 83E10014 38210018
125BEDC: 7C0803A6 4E800020 9421FFF0 7C0802A6 93E1000C 7C9F2378 90010014 48076675
125BEFC: 2F830000 409E000C 7FE3FB78 4BFCB265 80010014 83E1000C 38210010 7C0803A6
125BF1C: 4E800020 9421FFF0 7C0802A6 2F840000 93E1000C 7C7F1B78 90010014 419E0058
125BF3C: 480D0449 2F830000 409E0010 480D25B9 2F830000 419E0034 3D200471 7FE4FB78
125BF5C: 8069543C 4807660D 2F830000 409E0048 3C600301 3C80032D 38636EE4 3884589C
125BF7C: 4BF5AEB1 48000030 7FE3FB78 4BFCB1E5 48000024 3D200471 7FE4FB78 80695340
125BF9C: 480765D1 2F830000 409E000C 38600002 480EA80D 80010014 83E1000C 38210010
125BFBC: 7C0803A6 4E800020 9421FFF0 7C0802A6 93E1000C 7C9F2378 90010014 480759F1
125BFDC: 2F830000 409E0020 80010014 7FE3FB78 38800001 83E1000C 38210010 7C0803A6
---- block3 ptr=2C5C684 is_malloc=0 length=0x100 ----
2C5C644: 4A5FF8A1 8001000C 38210008 7C0803A6 4E800020 9421FFF8 7C0802A6 3D200471
2C5C664: 7C641B78 9001000C 806963FC 4A5FF875 8001000C 38210008 7C0803A6 4E800020
2C5C684: 9421FFF0 7C0802A6 93E1000C 7C7F1B78 90010014 80030044 70090010 41820034
2C5C6A4: 38800002 38A00000 4A606931 3D200471 80696518 7FE4FB78 4A5FF829 80010014
2C5C6C4: 83E1000C 38210010 7C0803A6 4E800020 3D200471 7FE4FB78 806963FC 4A5FF805
2C5C6E4: 4A79EA09 80010014 83E1000C 38210010 7C0803A6 4E800020 9421FFE0 7C0802A6
2C5C704: 3D200471 93410008 7C9A2378 93E1001C 7C7F1B78 9361000C 93810010 93A10014
2C5C724: 93C10018 90010024 81695358 8003003C 7F805800 419E0010 4BFF0771 2F830001
2C5C744: 419E00A4 83DF0034 807F0118 839F00A4 801E0010 7F830000 419E0070 3D200471
2C5C764: 807F003C 80096144 2F800000 409E003C 7FE3FB78 38800000 38A00001 480093C9
---- block5 ptr=234 is_malloc=0 length=0x100 ----
1F4: FFEFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFF7FF FFFFFFFF
214: FFDFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
234: FFFFFFFF FFFFFFFF 7FFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
254: FFEFFEFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
274: FFFFFFEF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF BFFFFFFF FFFFFFFF FFFFFFFF
294: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
2B4: FFFFF7FF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF DFFFFFFF FFFFFFFF
2D4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
2F4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
314: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block6 ptr=1EBDCD68 is_malloc=1 length=0xA00 ----
1EBDCD28: 0 0 0 0 0 0 0 0
1EBDCD48: 0 0 0 0 0 0 0 FD0110DF
1EBDCD68: AB1234CD FFFE0000 0 32CF9F0 12253B4 1EBDD82C 1EBDC2B8 8000054A
1EBDCD88: 1 0 1000001 519B9D0 AFACEFAD 0 0 0
1EBDCDA8: 0 0 0 0 0 0 0 0
1EBDCDC8: 0 0 0 0 0 0 0 0
1EBDCDE8: 0 0 0 0 0 0 0 0
1EBDCE08: 0 0 0 0 0 0 0 0
1EBDCE28: 0 0 0 0 0 0 0 0
1EBDCE48: 0 0 0 0 0 0 0 0
1EBDCE68: 0 0 0 0 0 0 0 0
1EBDCE88: 0 0 0 0 0 0 0 0
1EBDCEA8: 0 0 0 0 0 0 0 0
1EBDCEC8: 0 0 0 0 0 0 0 0
1EBDCEE8: 0 0 0 0 0 0 0 0
1EBDCF08: 0 0 0 0 0 0 0 0
1EBDCF28: 0 0 0 0 0 0 0 0
1EBDCF48: 0 0 0 0 0 0 0 0
1EBDCF68: 0 0 0 0 0 0 0 0
1EBDCF88: 0 0 0 0 0 0 0 0
1EBDCFA8: 0 0 0 0 0 0 0 0
1EBDCFC8: 0 0 0 0 0 0 0 0
1EBDCFE8: 0 0 0 0 0 0 0 0
1EBDD008: 0 0 0 0 0 0 0 0
1EBDD028: 0 0 0 0 0 0 0 0
1EBDD048: 0 0 0 0 0 0 0 0
1EBDD068: 0 0 0 0 0 0 0 0
1EBDD088: 0 0 0 0 0 0 0 0
1EBDD0A8: 0 0 0 0 0 0 0 0
1EBDD0C8: 0 0 0 0 0 0 0 0
1EBDD0E8: 0 0 0 0 0 0 0 0
1EBDD108: 0 0 0 0 0 0 0 0
1EBDD128: 0 0 0 0 0 0 0 0
1EBDD148: 0 0 0 0 0 0 0 0
1EBDD168: 0 0 0 0 0 0 0 0
1EBDD188: 0 0 0 0 0 0 0 0
1EBDD1A8: 0 0 0 0 0 0 0 0
1EBDD1C8: 0 0 0 0 0 0 0 0
1EBDD1E8: 0 0 0 0 0 0 0 0
1EBDD208: 0 0 0 0 0 0 0 0
1EBDD228: 0 0 0 0 0 0 0 0
1EBDD248: 0 0 0 0 0 0 0 0
1EBDD268: 0 0 0 0 0 0 0 0
1EBDD288: 0 0 0 0 0 0 0 0
1EBDD2A8: 0 0 0 0 0 0 0 0
1EBDD2C8: 0 0 0 0 0 0 0 0
1EBDD2E8: 0 0 0 0 0 0 0 0
1EBDD308: 0 0 0 0 0 0 0 0
1EBDD328: 0 0 0 0 0 0 0 0
1EBDD348: 0 0 0 0 0 0 0 0
1EBDD368: 0 0 0 0 0 0 0 0
1EBDD388: 0 0 0 0 0 0 0 0
1EBDD3A8: 0 0 0 0 0 0 0 0
1EBDD3C8: 0 0 0 0 0 0 0 0
1EBDD3E8: 0 0 0 0 0 0 0 0
1EBDD408: 0 0 0 0 0 0 0 0
1EBDD428: 0 0 0 0 0 0 0 0
1EBDD448: 0 0 0 0 0 0 0 0
1EBDD468: 0 0 0 0 0 0 0 0
1EBDD488: 0 0 0 0 0 0 0 0
1EBDD4A8: 0 0 0 0 0 0 0 0
1EBDD4C8: 0 0 0 0 0 0 0 0
1EBDD4E8: 0 0 0 0 0 0 0 0
1EBDD508: 0 0 0 0 0 0 0 0
1EBDD528: 0 0 0 0 0 0 0 0
1EBDD548: 0 0 0 0 0 0 0 0
1EBDD568: 0 0 0 0 0 0 0 0
1EBDD588: 0 0 0 0 0 0 0 0
1EBDD5A8: 0 0 0 0 0 0 0 0
1EBDD5C8: 0 0 0 0 0 0 0 0
1EBDD5E8: 0 0 0 0 0 0 0 0
1EBDD608: 0 0 0 0 0 0 0 0
1EBDD628: 0 0 0 0 0 0 0 0
1EBDD648: 0 0 0 0 0 0 0 0
1EBDD668: 0 0 0 0 0 0 0 0
1EBDD688: 0 0 0 0 0 0 0 0
1EBDD6A8: 0 0 0 0 0 0 0 0
1EBDD6C8: 0 0 0 0 0 0 0 0
1EBDD6E8: 0 0 0 0 0 0 0 0
1EBDD708: 0 0 0 0 0 0 0 0
1EBDD728: 0 0 0 0 0 0 0 0
1EBDD748: 0 0 0 0 0 0 0 0
---- block7 ptr=32CF9E0 is_malloc=0 length=0x100 ----
32CF9A0: 61746520 506F6F6C 73000000 48656164 65722050 6F6F6C73 0 4D454D50
32CF9C0: 4F4F4C5F 434C4153 535F4C4F 43414C00 706F6F6C 5F676574 62756666 65720000
32CF9E0: 2A506163 6B657420 48656164 65722A00 2A506163 6B657420 44617461 2A000000
32CFA00: 7365713A 20636100 50415254 49434C45 50414B44 55504641 494C0000 50617274
32CFA20: 69636C65 20706163 6B657420 6475706C 69636174 696F6E20 61747465 6D707465
32CFA40: 64206F6E 206E6F6E 2D706172 7469636C 65207061 636B6574 A000000 536D616C
32CFA60: 6C000000 4D696464 6C650000 56657279 42696700 4C617267 65000000 48756765
32CFA80: 0 64617461 6772616D 5F646F6E 65000000 73636174 74657265 64000000
32CFAA0: 636F6E74 6967756F 75732073 72630000 636F6E74 6967756F 75732064 73740000
32CFAC0: 70616B5F 656E7175 65756500 5061636B 65742045 6C656D65 6E747320 43616368
---- block8 ptr=516AE54 is_malloc=0 length=0x100 ----
516AE14: EF5E35C9 818F6293 DEF3BB62 B05D38C3 A6B76A3D 215B765B B44156E5 B91F8FD
516AE34: 525DE5CA 3442095D B04BE1EC E82B65F4 CA48361B 542AE987 CC6C27FF AB3F7462
516AE54: A17BA0D3 A750C39A EA97BA87 309935B7 E60657DA CBD34F10 7D320862 CAB9209B
516AE74: 29A15992 BF8EA51E 9CC0E82B B09FBBCD 8FDA30C9 64D627A6 F69A8E2B 58E0117
516AE94: C98F7858 8028FCBF FF142A39 9C08079A F31EA8F9 1F31CE94 464EC031 5A528C93
516AEB4: 63F68C7 984D934C 5258B78C 235A2161 F24109F 7FD917B0 E70D5D78 57EEBB55
516AED4: F42B5998 281B10E9 7052D55C 7A5A1748 199DB53B 985756C6 5590071B 605AFF4E
516AEF4: 5C431416 3F242519 E1CD75AA 76466058 136DEC2B D94F00D5 594FDAE1 68EB13EF
516AF14: 36C7D2AE 1C5627 1B7327D5 9613DB4F 47021CA4 A849521C D8A12D0F 4C8411C
516AF34: 65464712 4D85D780 C74A564E DCDF4CE6 9C4700D6 55871EB EE463E13 4ABE3F1F
---- block9 ptr=91E8A34 is_malloc=1 length=0x4E4 ----
91E89F4: 0 0 0 0 0 0 0 0
91E8A14: 0 0 0 9B5FBD8 67 91E8A64 91E809C FD0110DF
91E8A34: AB1234CD FFFE0000 0 32CF9E0 1225354 91E8F18 91E8564 8000025A
91E8A54: 1 0 1000001 519B9D0 0 1E30CEA6 0 0
91E8A74: 9ADA8A4 0 FFFF0007 10000 1E30CC78 1E30CE4C 1E30CE4C 1E30CE4C
91E8A94: 0 1E30CE5A 0 A4B71EC 1E30D5F8 200 3C0001 1000E
91E8AB4: 0 0 0 0 0 FF000000 0 0
91E8AD4: 0 0 0 0 0 0 0 0
91E8AF4: 0 0 0 0 0 0 1 0
91E8B14: 6534194 0 1B6F12C 14 1E4DD2EE 0 0 0
91E8B34: 0 0 0 0 0 0 0 0
91E8B54: 0 0 0 0 0 0 0 0
91E8B74: 0 0 0 0 0 0 0 0
91E8B94: 0 39C36E0 0 39C4280 0 0 0 0
91E8BB4: 0 0 0 0 0 0 0 0
91E8BD4: 0 0 0 6533684 0 0 0 0
91E8BF4: 0 0 0 CEADEA5E 0 0 0 0
91E8C14: 0 0 0 0 0 0 0 0
91E8C34: 0 0 0 0 0 0 0 0
91E8C54: 0 0 0 0 0 0 0 0
91E8C74: 0 0 0 0 0 0 0 0
91E8C94: 0 0 0 0 0 0 0 0
91E8CB4: 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E8CD4: FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E8CF4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E8D14: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E8D34: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 0 0 0
91E8D54: 0 0 0 0 0 0 0 24
91E8D74: 0 0 0 0 0 0 0 0
91E8D94: 0 0 0 0 0 0 0 0
91E8DB4: 0 0 0 0 0 0 0 0
91E8DD4: 0 0 0 0 0 0 0 0
91E8DF4: 0 0 0 0 0 0 0 0
91E8E14: 0 0 0 0 0 0 0 0
91E8E34: 0 0 0 0 0 0 0 0
91E8E54: 0 0 0 0 0 0 0 0
91E8E74: 0 0 0 0 0 0 0 0
91E8E94: 0 0 0 0 0 0 0 0
91E8EB4: 0 0 0 0 0 0 0 0
91E8ED4: 0 0 0 0 0 0 0 0
91E8EF4: 0 0 0 0 9B61420 42 91E8F48 91E8580
91E8F14: FD0110DF
---- block10 ptr=91E8550 is_malloc=1 length=0x4E4 ----
91E8510: 0 0 0 0 0 0 0 0
91E8530: 0 0 0 9B61420 42 91E8580 91E7BB8 FD0110DF
91E8550: AB1234CD FFFE0000 0 32CF9E0 1225354 91E8A34 91E8080 8000025A
91E8570: 1 0 1000001 519B9D0 0 1E30C3F2 0 0
91E8590: 9ADBAF0 0 FFFF0000 10000 1E30C1B4 1E30C36C 1E30C3BC 1E30C3BC
91E85B0: 0 1E30C238 0 0 1E30CB34 0 2300001 1000E
91E85D0: 0 0 0 0 0 FF000000 0 0
91E85F0: 0 0 0 0 0 0 0 0
91E8610: 0 0 0 0 0 0 1 0
91E8630: 6534194 0 188C094 14 1E499E6E 0 0 0
91E8650: 0 0 0 0 0 0 0 0
91E8670: 0 0 0 0 0 0 0 0
91E8690: 0 0 0 0 0 0 0 0
91E86B0: 0 37F2028 0 39C4244 0 0 0 0
91E86D0: 0 0 0 0 0 0 0 0
91E86F0: 0 0 0 6533684 0 0 0 0
91E8710: 0 0 0 CEADEA5E 0 0 FACD1010 0
91E8730: 0 0 0 0 0 0 0 0
91E8750: 0 0 0 0 0 0 0 0
91E8770: 0 0 0 0 0 0 0 0
91E8790: 0 0 0 0 0 0 0 0
91E87B0: 0 0 0 0 0 0 0 0
91E87D0: 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E87F0: FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E8810: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E8830: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E8850: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 0 0 0
91E8870: 0 0 0 0 0 0 0 34
91E8890: 0 0 0 0 0 0 0 0
91E88B0: 0 41 0 0 0 0 0 0
91E88D0: 0 0 0 0 0 0 0 0
91E88F0: 0 0 0 0 0 0 0 0
91E8910: 0 0 0 0 0 0 0 0
91E8930: 0 0 0 0 0 0 0 0
91E8950: 0 0 0 0 0 0 0 0
91E8970: 0 0 0 0 0 0 0 0
91E8990: 0 0 0 0 0 0 0 0
91E89B0: 0 0 0 0 0 0 0 0
91E89D0: 0 0 0 0 0 0 0 0
91E89F0: 0 0 0 0 0 0 0 0
91E8A10: 0 0 0 0 9B5FBD8 67 91E8A64 91E809C
91E8A30: FD0110DF
---- block11 ptr=6772308 is_malloc=1 length=0xA00 ----
67722C8: 32602D8 13089C8 6772308 6772274 8000000E 1 0 1000001
67722E8: 519B9D0 0 0 0 0 0 0 FD0110DF
6772308: AB1234CD FFFE0000 0 32602D8 153061C 677238C 67722D0 8000002A
6772328: 1 0 1000001 519B9D0 99BC874 0 0 3
6772348: 1437DA 0 29635 28 0 6772360 9AD541C 0
6772368: 0 1D 6D8C0F 0 8A3914 104 0 0
6772388: FD0110DF AB1234CD FFFE0000 0 32D1020 10A3318 6773048 677231C
67723A8: 80000646 1 0 1000001 519B9D0 9958CE8 0 0
67723C8: 0 0 0 6533684 1B 0 153B984 3
67723E8: 0 0 1000000 0 0 0 0 2C5C028
6772408: 2 0 0 0 1 5F4 E 0
6772428: 0 0 6533684 0 34CC4E4 0 0 0
6772448: 5EA 0 0 0 0 0 0 FFFFFFFF
6772468: 0 32DA560 47B0A0C 9958BB8 9958C04 FFFFFFFF 2 4
6772488: 0 153A470 153A0E4 0 0 4 0 FFFFFFFF
67724A8: FFFFFFFF FFFFFFFF 0 0 0 0 0 0
67724C8: 0 0 0 0 0 0 0 0
67724E8: 0 5DC05DC 1 0 0 474A1B0 67723BC 0
6772508: 0 0 0 44246 0 700 5F0 1
6772528: 6534194 0 210040 200010 0 0 10002200 0
6772548: 4 4 0 5 0 0 0 0
6772568: 39C3320 0 0 0 0 0 FB14 0
6772588: 0 4747910 67723BC 0 0 0 0 14246
67725A8: 0 7D0 7D0 0 3352658 6533C54 1 1
67725C8: 1 98 0 1FF 134DC7C 1010001 FF000009 0
67725E8: 39C4EA0 0 0 0 0 0 0 0
6772608: 0 0 0 0 0 0 0 0
6772628: 0 0 0 0 0 0 0 0
6772648: 0 0 0 28 28 28 28 28
6772668: 28 28 28 28 28 28 28 28
6772688: 28 28 28 28 0 0 0 28
67726A8: 0 0 0 28 0 0 0 28
67726C8: 0 0 0 28 0 0 0 28
67726E8: 0 0 0 28 0 0 0 28
6772708: 0 0 0 28 0 0 0 28
6772728: 0 0 0 28 0 0 0 28
6772748: 0 0 0 28 0 0 0 28
6772768: 0 0 0 28 0 0 0 28
6772788: 0 0 0 28 0 0 0 28
67727A8: 0 67723BC 0 0 B A77E A77E 0
67727C8: 0 0 12318CC 12322A0 0 0 134FAC0 134F3C0
67727E8: 0 10D3454 0 0 0 153AFA4 0 0
6772808: 2C519E8 122D7D0 122CF44 0 0 134E9D8 153681C 15375B8
6772828: 1350838 12550B4 134CE8C 0 134CF90 0 0 0
6772848: 0 1535C90 0 0 153753C 0 15367D8 0
6772868: 153A448 0 134CE14 0 0 0 0 0
6772888: 0 0 0 0 0 0 0 0
67728A8: 133D 0 0 74DD644E 4FD 0 0 20F2DD01
67728C8: BB6 0 0 B12F 0 0 0 3C53E5
67728E8: C5C8 0 0 0 0 0 0 0
6772908: 0 0 0 0 0 0 5F38B7 0
6772928: 0 0 0 0 0 0 0 0
6772948: 0 0 0 0 0 0 0 0
6772968: 0 0 0 0 0 0 0 0
6772988: ADCD 0 0 0 0 0 0 0
67729A8: 0 0 0 0 0 0 0 0
67729C8: 3 0 0 0 0 0 74F0A358 5F2CC6
67729E8: 1A0 8E2F69 226 0 0 0 0 E54
6772A08: 0 0 0 0 0 0 39C395C 6772AF0
6772A28: 6772B3C 0 0 0 0 0 0 0
6772A48: 0 54ACD48 0 0 0 0 0 54ACCB0
6772A68: 54ACC64 0 0 54ACCFC 0 0 0 0
6772A88: 0 0 0 0 0 0 0 0
6772AA8: 0 0 0 0 0 0 0 0
6772AC8: 0 0 0 0 0 0 0 0
6772AE8: 0 0 0 0 0 0 0 0
6772B08: 0 0 0 0 1F91 1026C5 0 0
6772B28: 0 0 0 0 0 8CF818 0 20BD22A4
6772B48: 0 0 0 0 0 0 0 82C0
6772B68: 106D90C 0 0 0 0 0 0 0
6772B88: 0 0 0 0 0 0 39C395C 0
6772BA8: 0 0 0 0 0 0 0 0
6772BC8: 6773078 677335C 0 9B84EFC 0 0 BF13C7C 0
6772BE8: 0 0 0 0 0 0 0 0
6772C08: 0 0 0 0 0 0 0 0
6772C28: 0 0 0 0 0 0 0 0
6772C48: 0 0 0 0 0 0 0 BF13C7C
6772C68: 0 0 0 0 0 0 0 0
6772C88: 0 0 0 0 0 0 0 0
6772CA8: 100 0 0 0 0 0 0 0
6772CC8: 0 81000000 0 0 0 0 0 0
6772CE8: 0 6533684 67723BC 0 0 0 0 0
---- block12 ptr=67722BC is_malloc=1 length=0x14C ----
677227C: 80000016 1 0 1000001 519B9D0 534F4150 204C4544 2050726F
677229C: 63657373 0 0 B8EAB79D 5197814 0 10000014 FD0110DF
67722BC: AB1234CD FFFE0000 0 32602D8 13089C8 6772308 6772274 8000000E
67722DC: 1 0 1000001 519B9D0 0 0 0 0
67722FC: 0 0 FD0110DF AB1234CD FFFE0000 0 32602D8 153061C
677231C: 677238C 67722D0 8000002A 1 0 1000001 519B9D0 99BC874
677233C: 0 0 3 1437DA 0 29635 28 0
677235C: 6772360 9AD541C 0 0 1D 6D8C0F 0 8A3914
677237C: 104 0 0 FD0110DF AB1234CD FFFE0000 0 32D1020
677239C: 10A3318 6773048 677231C 80000646 1 0 1000001 519B9D0
67723BC: 9958CE8 0 0 0 0 0 6533684 1B
67723DC: 0 153B984 3 0 0 1000000 0 0
67723FC: 0 0 2C5C028
---- block13 ptr=3CF0000 is_malloc=0 length=0x100 ----
3CEFFC0: 0 0 0 0 0 0 0 0
3CEFFE0: 0 0 0 0 0 0 0 0
3CF0000: 0 0 0 0 0 0 0 0
3CF0020: 0 0 0 0 0 0 0 0
3CF0040: 0 0 0 0 0 0 0 0
3CF0060: 0 0 0 0 0 0 0 0
3CF0080: 0 0 0 0 0 0 0 0
3CF00A0: 0 0 0 0 0 0 0 0
3CF00C0: 0 0 0 0 0 0 0 0
3CF00E0: 0 0 0 0 0 0 0 0
---- block14 ptr=3D20000 is_malloc=0 length=0x100 ----
3D1FFC0: 0 0 0 0 0 0 0 0
3D1FFE0: 0 0 0 0 0 0 0 0
3D20000: 0 0 0 0 0 0 0 0
3D20020: 0 0 0 0 0 0 0 0
3D20040: 0 0 0 0 0 0 0 0
3D20060: 0 0 0 0 0 0 0 0
3D20080: 0 0 0 0 0 0 0 0
3D200A0: 0 0 0 0 0 0 0 0
3D200C0: 0 0 0 0 0 0 0 0
3D200E0: 0 0 0 0 0 0 0 0
---- block15 ptr=4710000 is_malloc=0 length=0x100 ----
470FFC0: 0 0 0 0 0 0 0 0
470FFE0: 0 0 0 0 0 0 0 0
4710000: 0 0 0 0 0 0 0 0
4710020: 0 0 0 0 0 0 0 0
4710040: 0 0 0 0 0 0 0 0
4710060: 0 0 0 0 0 0 0 0
4710080: 0 0 0 0 0 0 0 0
47100A0: 0 0 0 0 0 0 0 0
47100C0: 0 0 0 0 0 0 0 0
47100E0: 0 0 0 0 0 0 0 0
---- block16 ptr=3808808 is_malloc=0 length=0x100 ----
38087C8: 0 132C088 0 0 0 34F7338 32F2F5C 38087FC
38087E8: B280004 2 11000000 0 0 11000000 0 0
3808808: 4715D4C 380893C 3808940 3808938 0 0 0 0
3808828: 4715D60 380894C 3808950 3808948 0 0 0 0
3808848: 4715D54 380895C 3808960 3808958 0 0 0 0
3808868: 4715D70 380896C 3808970 3808968 2328 2328 51671C4 3326710
3808888: 4715D6C 380897C 3808980 3808978 2328 2328 64AE7C0 3326678
38088A8: 4715D64 380898C 3808990 3808988 2328 2328 51658A0 33266B8
38088C8: 4715D7C 380899C 38089A0 3808998 2328 2328 5164D10 3326454
38088E8: 4715D68 38089AC 38089B0 38089A8 0 0 0 0
---- block17 ptr=47709D8 is_malloc=0 length=0x100 ----
4770998: 0 0 0 0 0 0 0 0
47709B8: 0 0 0 0 0 0 0 0
47709D8: 99BC874 0 0 0 9AD541C 0 0 0
47709F8: 0 0 0 0 0 0 0 0
4770A18: 0 0 0 0 0 0 0 0
4770A38: 0 0 0 0 0 0 0 0
4770A58: 0 516B9B0 0 0 0 0 0 0
4770A78: 0 0 0 0 0 0 0 0
4770A98: 0 0 0 0 0 0 0 0
4770AB8: 0 0 0 0 0 0 0 0
---- block18 ptr=1E30CC44 is_malloc=1 length=0xA00 ----
1E30CC04: 0 0 0 0 0 0 0 0
1E30CC24: 0 0 0 0 0 0 0 FD0110DF
1E30CC44: AB1234CD FFFE0000 0 32CF9F0 12253B4 1E30D708 1E30C194 8000054A
1E30CC64: 1 0 1000001 519B9D0 AFACEFAD 0 0 0
1E30CC84: 0 0 0 93BD8 9C000000 93D02 F0000000 0
1E30CCA4: 0 0 0 0 0 0 0 0
1E30CCC4: 0 0 0 0 0 0 0 0
1E30CCE4: 0 0 0 0 0 0 0 0
1E30CD04: 0 0 0 0 0 0 0 0
1E30CD24: 0 0 0 0 0 0 0 0
1E30CD44: 0 0 0 0 0 0 0 0
1E30CD64: 0 0 0 0 0 0 0 0
1E30CD84: 0 0 0 0 0 0 0 0
1E30CDA4: 0 0 0 0 0 0 0 0
1E30CDC4: 0 0 0 0 0 0 0 0
1E30CDE4: 0 0 0 0 0 0 0 91DF7AC
1E30CE04: 912A388 91E8A64 93D02F0 FEEDBAC2 8000 922BE54 8000 80004900
1E30CE24: CDEDFFFF 1000060 91B4618 100 1104CA4 300 0 6216C22E
1E30CE44: 2214421E 2605421E 188B9D5C DEC0001C 7F3E274D 8004500 284FAB 40003E06
1E30CE64: BBE20AFA 12F60A50 903C0E8 DE38E2A9 8A57C5ED 7C205010 FFFF3061 0
1E30CE84: 0 4000 3811D8FD ADC2A478 A5007A3 1BBC429 54E5874 1017828C
1E30CEA4: ADD0FE98 8E00683D 2277B311 C715B844 3667AA9D 8CA9AD1F D69B6694 3097F6DF
1E30CEC4: B0B32C72 49F79054 24E84988 519225DC A8249783 11FE3D49 632CF6BB 89B04301
1E30CEE4: B3979EC7 1ADAFD43 78B5A79F ECD3C8E1 C0D8D20D 8FF43E8 C759D96B 145A221F
1E30CF04: 4E0071F6 E6B597FE 1968DA6 9EFD60C2 9ADB8C29 ED34BE2 5FF43C25 29E3B462
1E30CF24: 7CA291C6 8E2B1E4C B5D7A74E 9D743041 6676AA77 84678CBF DAC3C886 16AE0067
1E30CF44: ACD76681 B8326984 D8B8139A F9F38893 4AC27259 7DF2F700 D00901B3 94E6C0D4
1E30CF64: 2884EF44 78A12A25 82D7DB9B 714BDFFA 9A89E68F F0EFFAEF 32E20F71 B3A417D3
1E30CF84: 3A2BF1 FE44F077 92B1B431 65385AB7 ECB0CCEF 2371784E F9611EA8 3978049E
1E30CFA4: 5365B5BB 5086408 1E405BC1 5D8739A5 6E3BB4AF DBFA296 D403CAA9 6AA0FD3D
1E30CFC4: 5B83C3FF 7E7EE902 55021EC8 F5D13B81 8CB488AB 4D643791 F497AD58 49690654
1E30CFE4: 68F1E94B 38522B17 F259478A 6EE8F4A0 57F99B35 F1F97A2D 4DA3B640 51F0A213
1E30D004: E5168508 57AFCDEF 1BCE6A09 A5507B0C E2A81E00 27F0CAA F3C09724 DE1DCE12
1E30D024: 5F249025 A17BCFB0 56035F80 91513866 8C61C41C 7A258BF1 1364B83C D0BAED42
1E30D044: D164C554 7D2A1C8C 951C5944 EAF9659C 289119E3 4E705264 24818C7 61DBC984
1E30D064: F9C17AA4 59BBAB58 A56F6E6D 11636A6B FEF14F64 D9CBF2EA 38946FE3 8BD095F
1E30D084: 6651B501 995E587C 3D510217 D7E2320E 539FA5E3 ACA2017B 7828DA1E BBF9D25E
1E30D0A4: 99DD0434 3D3FAA03 87F612A9 16EF367D 8ABF7320 D52600CC 6D655930 7A411F0D
1E30D0C4: 32569C5C F9D7C32 AB50E3A 2DC902BE DA717267 1818BF2 ACEC7ED3 452E10
1E30D0E4: 79456E22 BE2A1BC4 346788C1 C02AC280 C991295D 4DAB19E8 15EB1B3F B7729EA9
1E30D104: F583C5F 9957BD7F F60C2A01 F49DD126 4BC36BFB C0B12701 DDBD2E6B 5FE38B34
1E30D124: BF712CD2 E45DBCF8 9CA74B4B 81FED8E7 4B30CB9C F703A284 648BD88 C4197F6E
1E30D144: E482BF55 1E57D964 3A1EFE35 9210F3DE BDFDABD9 2B3C899C EAF31A1A B57DEA70
1E30D164: 42F6F486 978251D3 DE04B6FF 35694E83 B4A9707A E27A5458 5397A57F 9356E6D8
1E30D184: C1367A97 EFB6363C C2A57678 88F4A773 6B5D7BA AE3ED9C5 9F12C45E EA3D90F1
1E30D1A4: 8CDFCA97 D58CEB98 FBF6F901 4663A8C3 10263F74 D7C5844D 653160DA 3438637D
1E30D1C4: 4D476B6E 58A23733 C3246354 5DEC84D5 74F3EA02 B47763A0 E86287FC 903F5E21
1E30D1E4: 43A466CD CC182503 7F336595 FC3E682B 37880F9 D20DBED1 4C4DFDDE 3C6D0784
1E30D204: F6299529 D9AF352 C5526430 6C9E3682 52DB32AE 2B5F0B03 7F28E6B6 6C0F3654
1E30D224: 59E3250F 5933172 3B44D8D0 34A56787 5DC6492B 37431B3C 3714CEE6 80582915
1E30D244: A580DC38 2342EF2 81ABA18F 92E26B8C F6431F51 ABA732E2 6523D25 1279D09
1E30D264: DEEEF127 33B2BE74 24021B0D E842463E 3EE4D2F8 9479D6E6 AB9073E2 6AB6D142
1E30D284: 90EE9158 C609633F A29C0111 C659C96 90E6CFA7 D1CB1E14 E6D6857F E8CE4859
1E30D2A4: 1E6D5216 3CEFB00A 3C12E77E 1FCD4B28 EF0B4824 19CA5793 30731B17 BD47F0BB
1E30D2C4: C57A5E52 65DC2042 C77D8AFD 60281444 6B4A9EF1 19D32A0C FFEDC5A3 2A0C1764
1E30D2E4: 2256E40A F56A0B48 F7292DD6 D23B29A6 EC9106E B6B40A5A 75067DB9 E2E44853
1E30D304: EE0E59F8 EDECA06B F45D9D93 3B2F627D C422BB20 41B75039 B0859531 B7FCC3D
1E30D324: DF647997 95E72ED9 8E7C6E69 673868DF A0255530 65A2118 4DB7779B A563F6E8
1E30D344: F772A891 72C49981 288FCCFF 72494D0 283A2885 E635EB28 49347B76 F73A4E50
1E30D364: AFF566F5 5EF910B9 BDE67075 240898BD 64BA5CC A02D210A 635F17AE E19EA9C3
1E30D384: 37249C33 4D8B4054 1268CD6A D86C5981 6EA25F7D 956C224C 9351176D 3DDE9C1
1E30D3A4: 2125874F 786C8CB7 F66479A1 4A608CFA E2E0EA0B 4E812B9 A2B235ED F391E5AF
1E30D3C4: 3512ED1A E0C4F75A B6ADBCD8 D48BB2F8 28DE4D7F 83438527 2542664F 9459607D
1E30D3E4: C19D0365 A0030201 202031B E715300D 6092A86 4886F70D 1010B05 306331
1E30D404: B300906 3550406 13025553 3121301F 6035504 A131854 68652047 6F204461
1E30D424: 64647920 47726F75 702C2049 6E632E31 31302F06 355040B 1328476F 20446164
1E30D444: 64792043 6C617373 20322043 65727469 66696361 74696F6E 20417574 686F7269
1E30D464: 7479301E 170D3134 30313031 30373030 30305A17 D333130 35333030 37303030
1E30D484: 305A3081 83310B30 9060355 4061302 55533110 300E0603 55040813 7417269
1E30D4A4: 7A6F6E61 31133011 6035504 7130A53 6A7CA0DC 1EFF9ABA 7ACD15C5 C6FEF21
1E30D4C4: 9B72125F E5D5C0BC AC79CAA EEBDD7BD 0 0 0 0
1E30D4E4: 0 0 0 0 0 0 0 0
1E30D504: 0 0 0 0 0 0 0 0
1E30D524: 0 0 0 0 0 0 0 0
1E30D544: 0 0 0 0 0 0 0 0
1E30D564: 0 0 0 0 0 0 0 0
1E30D584: 0 0 0 0 0 0 0 0
1E30D5A4: 0 0 0 0 0 0 0 0
1E30D5C4: 0 0 0 0 0 0 0 0
1E30D5E4: 0 0 0 0 0 0 1A5CAE52 0
1E30D604: 20 C 7ACC40 1B5B006C 244540 40ADF3EE 476E308 7870
1E30D624: 0 0 E18559AE 3D20000 0 1E73E1C4 0 0
---- block19 ptr=9AD53EC is_malloc=1 length=0xA00 ----
9AD53AC: 0 0 0 0 0 0 0 0
9AD53CC: 0 0 0 0 0 0 0 FD0110DF
9AD53EC: AB1234CD FFFE0000 0 32D1020 10A3318 9AD60A8 9ACC14C 80000646
9AD540C: 1 0 1000001 519B9D0 67723BC 0 0 0
9AD542C: 0 0 9C694E0 EA 0 1828AAC 0 0
9AD544C: 0 0 0 0 0 0 2C5C028 16
9AD546C: 0 0 0 1 5EA E 0 0
9AD548C: 0 9C694E0 0 34CC4E4 0 0 0 5EA
9AD54AC: 0 0 0 0 0 1 0 0
9AD54CC: 32DA604 33C9900 64A015C 649FDD4 FFFFFFFF 6 3 0
9AD54EC: 180D02C 1803E9C 0 0 3 0 FFFFFFFF FFFFFFFF
9AD550C: FFFFFFFF 0 0 0 0 0 0 0
9AD552C: 0 0 0 0 0 0 0 0
9AD554C: 5DC05DC 1 0 0 474A1B0 9AD541C 0 0
9AD556C: 0 0 44246 0 5F4 8FC 1 6534194
9AD558C: 0 210040 10 0 0 10002200 0 4
9AD55AC: 5 0 5 0 0 0 0 0
9AD55CC: 0 39C42EC 0 0 0 188AC 0 0
9AD55EC: 4747910 9AD541C 0 0 0 0 14246 0
9AD560C: 0 0 0 36EE880 9C69A64 1 1 1
9AD562C: 0 0 0 180ECBC 101000D FF000009 0 0
9AD564C: 0 0 0 0 0 0 0 0
9AD566C: 0 0 0 0 0 0 0 0
9AD568C: 0 0 0 0 0 0 0 0
9AD56AC: 0 0 1E 1E 1E 1E 1E 1E
9AD56CC: 1E 1E 1E 1E 1E 1E 1E 1E
9AD56EC: 1E 1E 1E 0 0 0 1E 0
9AD570C: 0 0 1E 0 0 0 1E 0
9AD572C: 0 0 1E 0 0 0 1E 0
9AD574C: 0 0 1E 0 0 0 1E 0
9AD576C: 0 0 1E 0 0 0 1E 0
9AD578C: 0 0 1E 0 0 0 1E 0
9AD57AC: 0 0 1E 0 0 0 1E 0
9AD57CC: 0 0 1E 0 0 0 1E 0
9AD57EC: 0 0 1E 0 0 0 1E 0
9AD580C: 9AD541C 0 0 0 A77E A77E 0 0
9AD582C: 0 12318CC 12322A0 0 0 134FAC0 134F3C0 0
9AD584C: 10D3454 0 0 0 18273AC 0 0 2C519E8
9AD586C: 122D7D0 122CF44 0 0 134E9D8 1803C28 1803BEC 1350838
9AD588C: 18042C8 134CE8C 0 134CF90 0 0 0 0
9AD58AC: 17F1260 0 0 1803C20 17F1274 17F1274 0 0
9AD58CC: 0 0 0 0 0 0 0 0
9AD58EC: 0 0 0 0 0 0 0 5475B
9AD590C: 0 0 15105598 B94 0 0 8E36E9AF 52F
9AD592C: 0 0 6D8C5F 0 0 0 8E3CC921 0
9AD594C: 0 0 0 0 0 0 0 238
9AD596C: 0 0 0 0 0 55B64 104 0
9AD598C: 0 0 0 623 0 0 0 0
9AD59AC: 0 0 0 0 0 0 0 0
9AD59CC: 0 0 0 0 0 0 0 71
9AD59EC: 0 0 0 0 0 0 0 0
9AD5A0C: 0 0 0 0 0 0 0 3
9AD5A2C: 0 0 0 0 0 14775857 8A2E30 21B
9AD5A4C: 6D8640 1AF 104 0 0 0 290C9 0
9AD5A6C: 0 0 0 0 0 39C395C 9AD5B50 9AD5B9C
9AD5A8C: 0 0 0 0 0 0 0 0
9AD5AAC: 0 0 0 0 0 0 0 54ACC18
9AD5ACC: 0 0 0 0 0 0 0 0
9AD5AEC: 0 0 0 0 0 0 0 0
9AD5B0C: 0 0 0 0 0 0 0 0
9AD5B2C: 0 0 0 0 0 0 0 0
9AD5B4C: 0 0 0 0 0 0 0 0
9AD5B6C: 0 0 0 0 0 84C284 0 76E1CA
9AD5B8C: 0 0 0 0 0 0 0 0
9AD5BAC: 0 0 0 0 0 0 71 473A
9AD5BCC: 0 0 0 0 0 0 0 0
9AD5BEC: 0 0 0 0 0 39C395C 0 0
9AD5C0C: 0 0 0 0 0 0 0 9AD60D8
9AD5C2C: 64A00B4 9C7365C 9B84DD4 A50A3F4 A565CF8 BF14374 0 0
9AD5C4C: 0 0 0 0 0 0 0 0
9AD5C6C: 0 0 0 0 0 0 0 0
9AD5C8C: 0 0 0 0 0 0 0 0
9AD5CAC: 0 0 0 0 0 0 BF14374 0
9AD5CCC: 0 0 0 0 0 0 0 0
9AD5CEC: 0 0 0 0 0 0 0 600
9AD5D0C: 0 0 0 0 0 0 0 0
9AD5D2C: 0 0 0 0 0 0 0 0
9AD5D4C: 9C694E0 9AD541C 0 0 0 0 0 0
9AD5D6C: 0 0 0 0 0 0 0 0
9AD5D8C: 0 0 0 0 0 0 0 0
9AD5DAC: 17F1274 181D4DC 0 0 0 0 0 0
9AD5DCC: 0 0 0 0 0 0 0 0
---- block20 ptr=1E28D990 is_malloc=1 length=0xA00 ----
1E28D950: 0 0 0 0 0 0 0 0
1E28D970: 0 0 0 0 0 0 0 FD0110DF
1E28D990: AB1234CD FFFE0000 0 32CF9F0 12253B4 1E28E454 1E28CEE0 8000054A
1E28D9B0: 1 0 1000001 519B9D0 AFACEFAD 0 0 0
1E28D9D0: 0 0 0 0 0 91AEE 10000000 0
1E28D9F0: 0 0 0 0 0 0 0 0
1E28DA10: 0 0 0 0 0 0 0 0
1E28DA30: 0 0 0 0 0 0 0 0
1E28DA50: 0 0 0 0 0 0 0 0
1E28DA70: 0 0 0 0 0 0 0 0
1E28DA90: 0 0 0 0 0 0 0 0
1E28DAB0: 0 0 0 0 0 0 0 0
1E28DAD0: 0 0 0 0 0 0 0 0
1E28DAF0: 0 0 0 0 0 0 0 0
1E28DB10: 0 0 0 0 0 0 0 0
1E28DB30: 0 0 0 0 0 0 0 91568AC
1E28DB50: 912A388 91697E4 91AEE10 FEEDBAC2 8000 8000 80004900 CDEDFFFF
1E28DB70: 1000060 80004900 91A20A8 BADCEFBE 70B005E 3D3F803F 12000049 24240A3F
1E28DB90: 6048006 959A130B 80401D00 C0621D00 C0621500 C0621500 180CA100 8CC100
1E28DBB0: 500A547C 699A098F 188B9D5C DEC00800 450000A6 F8514000 40111B52 A500903
1E28DBD0: A500901 CDED147F 920000 204320 0 4C32100 0 1083000
1E28DBF0: 5C838F77 9ED01865 90DEA617 1C7F3E 274DFC90 AAAA0300 800 4500005A
1E28DC10: 4000 40062A23 A500683 36C0C8E8 CC8401BB 52F48534 ACB6A474 80181000
1E28DC30: BC3E0000 101080A 2C6C76FE A11B88A9 17030300 21000000 0 5752271
1E28DC50: 161C3603 6A0D2925 21E195C9 86E45E53 D3F77451 ADAA2405 4000000 0
1E28DC70: 0 0 0 7F080010 8000140 409606 409600 B00BF0C
1E28DC90: B259820F FAFF0000 FAFF0000 C005012A C0FFC3 4020202 2DD1800 50F20201
1E28DCB0: 1800003 A4000027 A4000042 435E0062 322F00DD 6004096 10104DD 5004096
1E28DCD0: 305DD05 40960B 9DD0500 40961401 1EFA8378 F1087E26 D943E6D7 ADC62DD3
1E28DCF0: 84D2F5D8 BEA612C4 7BB3274A B1014AEC 98C668A0 14660DB0 9B830898 9A465291
1E28DD10: B964E474 EF7E1B67 C8472564 183BE244 CCC369CC 5407A9ED 4AB9B365 47D5FFE6
1E28DD30: 899EE592 5978B980 170D60EA 21317F9E 2BF796E7 549417A8 E2389995 DDFE6CEF
1E28DD50: D24B3EB3 3E294C66 4F08CCF3 67308272 217DB479 5AD01BAB F9A7BB4A BFE6F966
1E28DD70: 646FF01F 4C76AA85 D00BEA45 A7EB1BC1 28DF5D04 E89E2ABC 4EEB221B FD0B6750
1E28DD90: 90B74E58 CACA34A9 504A62BE C6A20BC3 E60BD846 A799F764 9ABF8A17 FFDF5DF2
1E28DDB0: 58FA70FF 122983CF 6C835C22 9EC33190 8C33E887 BFE1B19C 30B9C1CF FE7F77EC
1E28DDD0: 539A8892 306ACB98 B1F1A0B2 9F52F3A 35350202 1D92F413 B9FB35A6 7B8C009
1E28DDF0: 2E73E0AD 7B0F193 DB711ECF 51730ABF 1FD5FD0E A903BFE1 811AE715 5E41A03A
1E28DE10: 28E67D82 3ABA255E 211405BF A17820CE BDB36F72 CCF5433F 6C95B511 C7CF308E
1E28DE30: E4B9EED9 8004A190 BBB13D0B 8202EF7D D4970673 7FFDFA6B 1FF76CD8 425C70CA
1E28DE50: EF27F6C4 CC8F6461 14556451 E559609F 38E1FC27 79649214 4E950310 711D89E3
1E28DE70: 91A5575A 96DDE8D6 4118106C 2F42D2BB 72DF28CD C7B3F6D6 59D6436B 4413C8A3
1E28DE90: 955BD8B3 FFA8DD00 8050F40D 31E59909 A29832B3 8101D71F 225F433C B533B0F8
1E28DEB0: 3D90EDE8 C4F7600F 8E8F76D8 25018613 E2C87740 998B0B20 CEEA334F 79B22141
1E28DED0: 8B24D094 F83B5101 6E996891 EAD3555 A86269D6 29DAEA38 AC29F90E AB31A39D
1E28DEF0: 719DF7F6 978A68FD 4766744B CF9C8620 5353C41E F9AF6824 9B166DF3 F11AB88
1E28DF10: 3EF8E2C2 C6CA8D7D 383A86AD 5B8F7E73 564E17CD 92F10049 2E02748A 591664A8
1E28DF30: D92BC934 38E5A652 B32EA509 6F3D49A8 BFDDB7C4 2ED49256 A0BADCB DA897D30
1E28DF50: 9D99B7C3 85D97A14 8AB15C11 1B2F53F4 AB69AC3 BA35B23C C87B142D 285CF060
1E28DF70: 1C615320 9F09BB1F 3CF907AD 79954E86 62D03E70 5F4D60AF 99BBAF2A 207BC6C5
1E28DF90: 23CD7B9F 8C5683AE 8C0FB39E E5DCA65B 62BF72F 9D14451C 9AB4D26D 52603B43
1E28DFB0: 3CFC0727 4E99E421 E1B43D6B FA62BEB4 5648A7B8 F2BE5D41 4956C180 7E706DF5
1E28DFD0: 80EA867A 61577BA7 947615BE D9270A68 C067559F E9303DDE D9C52BEE C816013D
1E28DFF0: 45C3B477 4F35E8F6 78F7AB7E 45024B1A 9D2900A1 5AB91E01 13EB059E 55C24
1E28E010: A6651E10 B8A0BC9D 79EC0EAA 1B11BEA4 D464551C 140DB416 A4CA4AB2 6329C35A
1E28E030: 28499FD7 A19EB4F7 54CEF3A4 1C050B39 613459F4 BA58DA6F C4BB05C E5A601CB
1E28E050: FC4265CA 63A821D5 FA37AAE8 503DC72D 25A2CFFE AB19EDB9 9D0C7B86 DC866D24
1E28E070: 2E9EB9DC B0C86A67 E46B964E 59FC4895 2AC46E18 418A9AB8 2B2DC47F 11E83059
1E28E090: 404D2DA 28A601D8 B4A3CD9E 9027B7EE CAC02F8A ABBB9F9F 5464A29A 341FED45
1E28E0B0: 5AEE90D9 BD345CDD 554F4FFA A0C482AC FC535F 98B3F06A EA864C0D D7B2AC39
1E28E0D0: 4ABBFCA7 5B62E5DB 4F53F1A1 B14AE8EC 5595835D 89BCC42A D3F236ED 56735671
1E28E0F0: 556C3FF7 727410A1 74D51F4E 95B9528C D580FA88 6585E36E 4D8E943A 7B0DC1EC
1E28E110: 5F23B24 B8CD1A01 4E8B4197 891419DE AE7C8A20 23011390 7C61BD5D C1ADBC30
1E28E130: 47CE0505 88CE74C4 BDED30 D50E7F75 DF1BD33E AEF5B4F5 DCA3A655 D553FD64
1E28E150: C5D1F33 C8483C4 2385BB57 F5010C85 E8D3C9E1 688C2419 61C2DBD1 AE2A3936
1E28E170: BDB4D3D1 F092BC74 B6C3CBDE 3E96AF65 62FCB059 3218B7C1 1EB89EC3 AA2D6570
1E28E190: 30516977 2F52514F 79727265 6E556D48 61643536 6C674D77 4B634454 517A5736
1E28E1B0: 53434859 7672646F 56685170 506B5871 44434754 434F3562 79463178 3564304C
1E28E1D0: 4E2F796B 35785338 75457348 556D5262 63533449 4F654A48 502B6E2F 5A523370
1E28E1F0: 6F6E4477 61654D7A 49493663 47444C64 2F386F69 75316D6B 96EE7B1 645B398
1E28E210: 8C2C1BEE 22647572 55555555 6464792E 0 0 0 0
1E28E230: 0 0 0 0 0 0 0 0
1E28E250: 0 0 0 0 0 0 0 0
1E28E270: 0 0 0 0 0 0 0 0
1E28E290: 0 0 0 0 0 0 0 0
1E28E2B0: 0 0 0 0 0 0 0 0
1E28E2D0: 0 0 0 0 0 0 0 0
1E28E2F0: 0 0 0 0 0 0 0 0
1E28E310: 0 0 0 0 0 0 0 0
1E28E330: 0 0 0 0 0 0 1A566D9D 0
1E28E350: 0 30 E4CC45 165B006C 244545 45AD0000 476E308 7870
1E28E370: 0 0 E27F1AE7 3D20000 0 1E28DBE4 0 0
---- block21 ptr=A500900 is_malloc=0 length=0x100 ----
A5008C0: 0 0 0 0 0 0 0 0
A5008E0: 0 0 0 0 0 0 0 0
A500900: 0 0 0 0 0 0 0 0
A500920: 0 0 0 0 0 0 0 0
A500940: 0 0 0 0 0 0 0 0
A500960: 0 0 0 0 0 0 0 0
A500980: 0 0 0 0 0 0 0 0
A5009A0: 0 0 0 0 0 0 0 0
A5009C0: 0 0 0 0 0 0 0 0
A5009E0: 0 0 0 0 0 0 0 0
---- block22 ptr=9C69A34 is_malloc=1 length=0xA00 ----
9C699F4: 0 0 0 0 0 0 0 0
9C69A14: 0 0 0 0 0 0 0 FD0110DF
9C69A34: AB1234CD FFFE0000 0 33C9718 1810EDC 9D66EE0 9C694C4 8007EA3E
9C69A54: 1 0 1000001 519B9D0 D15CD15C 0 0 0
9C69A74: 0 0 0 0 0 0 0 0
9C69A94: 0 0 0 0 0 0 0 0
9C69AB4: 0 0 0 0 0 0 0 0
9C69AD4: 0 0 0 0 0 0 0 0
9C69AF4: 0 0 0 0 0 0 0 0
9C69B14: 0 0 0 0 0 0 0 0
9C69B34: 0 0 0 0 0 0 0 0
9C69B54: 0 0 0 0 0 0 0 0
9C69B74: 0 0 0 0 2020105 0 0 0
9C69B94: 0 0 0 0 0 0 0 0
9C69BB4: 0 0 0 0 0 0 0 0
9C69BD4: 0 0 0 0 0 0 0 0
9C69BF4: 0 0 0 0 0 0 0 0
9C69C14: 0 0 0 0 0 0 0 0
9C69C34: 0 0 0 0 0 0 0 0
9C69C54: 0 0 0 0 0 0 0 0
9C69C74: 0 0 0 0 0 0 0 0
9C69C94: 0 0 0 0 0 0 0 0
9C69CB4: 0 0 0 0 0 0 0 0
9C69CD4: 0 0 0 0 0 0 0 0
9C69CF4: 0 0 0 0 0 0 0 0
9C69D14: 0 0 0 0 0 0 0 0
9C69D34: 0 0 0 0 0 0 0 0
9C69D54: 0 0 0 0 0 0 0 0
9C69D74: 0 0 0 0 0 0 0 0
9C69D94: 0 0 0 0 0 0 0 0
9C69DB4: 0 0 0 0 0 0 0 0
9C69DD4: 0 0 0 0 0 0 0 0
9C69DF4: 0 0 0 0 0 0 0 0
9C69E14: 0 0 0 0 0 0 0 0
9C69E34: 0 0 0 0 0 1 0 0
9C69E54: 26B 0 80 0 0 23 0 0
9C69E74: 9D15948 0 9C6AA28 0 0 0 0 0
9C69E94: 0 0 0 0 0 0 0 0
9C69EB4: 0 0 0 0 0 0 0 0
9C69ED4: 0 0 0 0 0 0 0 0
9C69EF4: 0 0 0 0 0 0 0 0
9C69F14: 0 0 0 0 0 0 0 0
9C69F34: 0 0 0 0 0 0 0 0
9C69F54: 0 0 0 0 0 0 0 0
9C69F74: 0 0 0 0 0 0 0 0
9C69F94: 0 0 0 0 0 0 0 0
9C69FB4: 0 0 0 0 0 0 0 0
9C69FD4: 0 0 0 0 0 0 0 0
9C69FF4: 0 0 0 0 0 0 0 0
9C6A014: 0 0 0 0 0 0 0 0
9C6A034: 0 0 0 0 0 0 0 0
9C6A054: 0 0 0 0 0 0 0 0
9C6A074: 0 0 0 0 0 0 0 0
9C6A094: 0 0 0 0 0 0 0 0
9C6A0B4: 0 0 0 0 0 0 0 0
9C6A0D4: 0 0 0 0 0 0 0 0
9C6A0F4: 0 0 0 0 0 0 0 0
9C6A114: 0 0 0 0 0 0 0 1
9C6A134: 2 0 0 541 9 400 0 7
9C6A154: 190 0 0 9D1595C 0 9C69E78 0 0
9C6A174: 0 0 0 0 0 0 0 0
9C6A194: 0 0 0 0 0 0 0 0
9C6A1B4: 0 0 0 0 0 0 0 0
9C6A1D4: 0 0 0 0 0 0 0 0
9C6A1F4: 0 0 0 0 0 0 0 0
9C6A214: 0 0 0 0 0 0 0 0
9C6A234: 0 0 0 0 0 0 0 0
9C6A254: 0 0 0 0 0 0 0 0
9C6A274: 0 0 0 0 0 0 0 0
9C6A294: 0 0 0 0 0 0 0 0
9C6A2B4: 0 0 0 0 0 0 0 0
9C6A2D4: 0 0 0 0 0 0 0 0
9C6A2F4: 0 0 0 0 0 0 0 0
9C6A314: 0 0 0 0 0 0 0 0
9C6A334: 0 0 0 0 0 0 0 0
9C6A354: 0 0 0 0 0 0 0 0
9C6A374: 0 0 0 0 0 0 0 0
9C6A394: 0 0 0 0 0 0 0 0
9C6A3B4: 0 0 0 0 0 0 0 0
9C6A3D4: 0 0 0 0 0 0 0 0
9C6A3F4: 0 0 0 0 0 0 0 0
9C6A414: 0 0 2 3 0 0 F1 0
---- block23 ptr=926FBDC is_malloc=1 length=0x4E4 ----
926FB9C: 0 0 0 0 0 0 0 0
926FBBC: 0 0 0 9B61420 42 926FC0C 926F244 FD0110DF
926FBDC: AB1234CD FFFE0000 0 32CF9E0 1225354 92700C0 926F70C 8000025A
926FBFC: 1 0 1000001 519B9D0 0 1E4364F6 0 0
926FC1C: 9AD9A24 0 FFFF0000 0 1E4362E0 1E4364D6 1E436508 1E436508
926FC3C: 0 1E4364FC 0 0 1E436C60 0 24B0001 1000E
926FC5C: 0 0 0 0 0 FF000000 0 0
926FC7C: 0 0 0 0 0 0 0 0
926FC9C: 0 0 0 0 0 0 1 0
926FCBC: 6534194 0 1FEDCDC 14 1E4B626E 0 0 0
926FCDC: 0 0 0 0 0 0 0 0
926FCFC: 0 0 0 0 0 0 0 0
926FD1C: 0 0 0 0 0 0 0 0
926FD3C: 0 347BE74 0 34E00C0 0 0 0 0
926FD5C: 0 0 0 0 0 0 0 0
926FD7C: 0 0 0 6533684 0 0 0 0
926FD9C: 0 0 0 CEADEA5E 0 0 0 0
926FDBC: 0 0 0 0 0 0 0 0
926FDDC: 0 0 0 0 0 0 0 0
926FDFC: 0 0 0 0 0 0 0 0
926FE1C: 0 0 0 0 0 0 0 0
926FE3C: 0 0 0 0 0 0 0 0
926FE5C: 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
926FE7C: FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
926FE9C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
926FEBC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
926FEDC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 0 0 0
926FEFC: 0 0 0 0 0 0 0 24
926FF1C: 0 0 0 0 0 0 0 0
926FF3C: 0 0 0 0 0 0 0 0
926FF5C: 0 0 0 0 0 0 0 0
926FF7C: 0 0 0 0 0 0 0 0
926FF9C: 0 0 0 0 0 0 0 0
926FFBC: 0 0 0 0 0 0 0 0
926FFDC: 0 0 0 0 0 0 0 0
926FFFC: 0 0 0 0 0 0 0 0
927001C: 0 0 0 0 0 0 0 0
927003C: 0 0 0 0 0 0 0 0
927005C: 0 0 0 0 0 0 0 0
927007C: 0 0 0 0 0 0 0 0
927009C: 0 0 0 0 9B5FBD8 67 92700F0 926F728
92700BC: FD0110DF
---- block24 ptr=1EBDD82C is_malloc=1 length=0xA00 ----
1EBDD7EC: 0 0 0 0 0 0 0 0
1EBDD80C: 0 0 0 0 0 0 0 FD0110DF
1EBDD82C: AB1234CD FFFE0000 0 32CF9F0 12253B4 1EBDE2F0 1EBDCD7C 8000054A
1EBDD84C: 1 0 1000001 519B9D0 AFACEFAD 0 0 0
1EBDD86C: 0 0 0 0 0 0 0 0
1EBDD88C: 0 0 0 0 0 0 0 0
1EBDD8AC: 0 0 0 0 0 0 0 0
1EBDD8CC: 0 0 0 0 0 0 0 0
1EBDD8EC: 0 0 0 0 0 0 0 0
1EBDD90C: 0 0 0 0 0 0 0 0
1EBDD92C: 0 0 0 0 0 0 0 0
1EBDD94C: 0 0 0 0 0 0 0 0
1EBDD96C: 0 0 0 0 0 0 0 0
1EBDD98C: 0 0 0 0 0 0 0 0
1EBDD9AC: 0 0 0 0 0 0 0 0
1EBDD9CC: 0 0 0 0 0 0 0 0
1EBDD9EC: 0 0 0 0 0 0 0 0
1EBDDA0C: 0 0 0 0 0 0 0 0
1EBDDA2C: 0 0 0 0 0 0 0 0
1EBDDA4C: 0 0 0 0 0 0 0 0
1EBDDA6C: 0 0 0 0 0 0 0 0
1EBDDA8C: 0 0 0 0 0 0 0 0
1EBDDAAC: 0 0 0 0 0 0 0 0
1EBDDACC: 0 0 0 0 0 0 0 0
1EBDDAEC: 0 0 0 0 0 0 0 0
1EBDDB0C: 0 0 0 0 0 0 0 0
1EBDDB2C: 0 0 0 0 0 0 0 0
1EBDDB4C: 0 0 0 0 0 0 0 0
1EBDDB6C: 0 0 0 0 0 0 0 0
1EBDDB8C: 0 0 0 0 0 0 0 0
1EBDDBAC: 0 0 0 0 0 0 0 0
1EBDDBCC: 0 0 0 0 0 0 0 0
1EBDDBEC: 0 0 0 0 0 0 0 0
1EBDDC0C: 0 0 0 0 0 0 0 0
1EBDDC2C: 0 0 0 0 0 0 0 0
1EBDDC4C: 0 0 0 0 0 0 0 0
1EBDDC6C: 0 0 0 0 0 0 0 0
1EBDDC8C: 0 0 0 0 0 0 0 0
1EBDDCAC: 0 0 0 0 0 0 0 0
1EBDDCCC: 0 0 0 0 0 0 0 0
1EBDDCEC: 0 0 0 0 0 0 0 0
1EBDDD0C: 0 0 0 0 0 0 0 0
1EBDDD2C: 0 0 0 0 0 0 0 0
1EBDDD4C: 0 0 0 0 0 0 0 0
1EBDDD6C: 0 0 0 0 0 0 0 0
1EBDDD8C: 0 0 0 0 0 0 0 0
1EBDDDAC: 0 0 0 0 0 0 0 0
1EBDDDCC: 0 0 0 0 0 0 0 0
1EBDDDEC: 0 0 0 0 0 0 0 0
1EBDDE0C: 0 0 0 0 0 0 0 0
1EBDDE2C: 0 0 0 0 0 0 0 0
1EBDDE4C: 0 0 0 0 0 0 0 0
1EBDDE6C: 0 0 0 0 0 0 0 0
1EBDDE8C: 0 0 0 0 0 0 0 0
1EBDDEAC: 0 0 0 0 0 0 0 0
1EBDDECC: 0 0 0 0 0 0 0 0
1EBDDEEC: 0 0 0 0 0 0 0 0
1EBDDF0C: 0 0 0 0 0 0 0 0
1EBDDF2C: 0 0 0 0 0 0 0 0
1EBDDF4C: 0 0 0 0 0 0 0 0
1EBDDF6C: 0 0 0 0 0 0 0 0
1EBDDF8C: 0 0 0 0 0 0 0 0
1EBDDFAC: 0 0 0 0 0 0 0 0
1EBDDFCC: 0 0 0 0 0 0 0 0
1EBDDFEC: 0 0 0 0 0 0 0 0
1EBDE00C: 0 0 0 0 0 0 0 0
1EBDE02C: 0 0 0 0 0 0 0 0
1EBDE04C: 0 0 0 0 0 0 0 0
1EBDE06C: 0 0 0 0 0 0 0 0
1EBDE08C: 0 0 0 0 0 0 0 0
1EBDE0AC: 0 0 0 0 0 0 0 0
1EBDE0CC: 0 0 0 0 0 0 0 0
1EBDE0EC: 0 0 0 0 0 0 0 0
1EBDE10C: 0 0 0 0 0 0 0 0
1EBDE12C: 0 0 0 0 0 0 0 0
1EBDE14C: 0 0 0 0 0 0 0 0
1EBDE16C: 0 0 0 0 0 0 0 0
1EBDE18C: 0 0 0 0 0 0 0 0
1EBDE1AC: 0 0 0 0 0 0 0 0
1EBDE1CC: 0 0 0 0 0 0 0 0
1EBDE1EC: 0 0 0 0 0 0 0 0
1EBDE20C: 0 0 0 0 0 0 0 0
---- block25 ptr=1EBDC2A4 is_malloc=1 length=0xA00 ----
1EBDC264: 0 0 0 0 0 0 0 0
1EBDC284: 0 0 0 0 0 0 0 FD0110DF
1EBDC2A4: AB1234CD FFFE0000 0 32CF9F0 12253B4 1EBDCD68 1EBDB7F4 8000054A
1EBDC2C4: 1 0 1000001 519B9D0 AFACEFAD 0 0 0
1EBDC2E4: 0 0 0 0 0 0 0 0
1EBDC304: 0 0 0 0 0 0 0 0
1EBDC324: 0 0 0 0 0 0 0 0
1EBDC344: 0 0 0 0 0 0 0 0
1EBDC364: 0 0 0 0 0 0 0 0
1EBDC384: 0 0 0 0 0 0 0 0
1EBDC3A4: 0 0 0 0 0 0 0 0
1EBDC3C4: 0 0 0 0 0 0 0 0
1EBDC3E4: 0 0 0 0 0 0 0 0
1EBDC404: 0 0 0 0 0 0 0 0
1EBDC424: 0 0 0 0 0 0 0 0
1EBDC444: 0 0 0 0 0 0 0 0
1EBDC464: 0 0 0 0 0 0 0 0
1EBDC484: 0 0 0 0 0 0 0 0
1EBDC4A4: 0 0 0 0 0 0 0 0
1EBDC4C4: 0 0 0 0 0 0 0 0
1EBDC4E4: 0 0 0 0 0 0 0 0
1EBDC504: 0 0 0 0 0 0 0 0
1EBDC524: 0 0 0 0 0 0 0 0
1EBDC544: 0 0 0 0 0 0 0 0
1EBDC564: 0 0 0 0 0 0 0 0
1EBDC584: 0 0 0 0 0 0 0 0
1EBDC5A4: 0 0 0 0 0 0 0 0
1EBDC5C4: 0 0 0 0 0 0 0 0
1EBDC5E4: 0 0 0 0 0 0 0 0
1EBDC604: 0 0 0 0 0 0 0 0
1EBDC624: 0 0 0 0 0 0 0 0
1EBDC644: 0 0 0 0 0 0 0 0
1EBDC664: 0 0 0 0 0 0 0 0
1EBDC684: 0 0 0 0 0 0 0 0
1EBDC6A4: 0 0 0 0 0 0 0 0
1EBDC6C4: 0 0 0 0 0 0 0 0
1EBDC6E4: 0 0 0 0 0 0 0 0
1EBDC704: 0 0 0 0 0 0 0 0
1EBDC724: 0 0 0 0 0 0 0 0
1EBDC744: 0 0 0 0 0 0 0 0
1EBDC764: 0 0 0 0 0 0 0 0
1EBDC784: 0 0 0 0 0 0 0 0
1EBDC7A4: 0 0 0 0 0 0 0 0
1EBDC7C4: 0 0 0 0 0 0 0 0
1EBDC7E4: 0 0 0 0 0 0 0 0
1EBDC804: 0 0 0 0 0 0 0 0
1EBDC824: 0 0 0 0 0 0 0 0
1EBDC844: 0 0 0 0 0 0 0 0
1EBDC864: 0 0 0 0 0 0 0 0
1EBDC884: 0 0 0 0 0 0 0 0
1EBDC8A4: 0 0 0 0 0 0 0 0
1EBDC8C4: 0 0 0 0 0 0 0 0
1EBDC8E4: 0 0 0 0 0 0 0 0
1EBDC904: 0 0 0 0 0 0 0 0
1EBDC924: 0 0 0 0 0 0 0 0
1EBDC944: 0 0 0 0 0 0 0 0
1EBDC964: 0 0 0 0 0 0 0 0
1EBDC984: 0 0 0 0 0 0 0 0
1EBDC9A4: 0 0 0 0 0 0 0 0
1EBDC9C4: 0 0 0 0 0 0 0 0
1EBDC9E4: 0 0 0 0 0 0 0 0
1EBDCA04: 0 0 0 0 0 0 0 0
1EBDCA24: 0 0 0 0 0 0 0 0
1EBDCA44: 0 0 0 0 0 0 0 0
1EBDCA64: 0 0 0 0 0 0 0 0
1EBDCA84: 0 0 0 0 0 0 0 0
1EBDCAA4: 0 0 0 0 0 0 0 0
1EBDCAC4: 0 0 0 0 0 0 0 0
1EBDCAE4: 0 0 0 0 0 0 0 0
1EBDCB04: 0 0 0 0 0 0 0 0
1EBDCB24: 0 0 0 0 0 0 0 0
1EBDCB44: 0 0 0 0 0 0 0 0
1EBDCB64: 0 0 0 0 0 0 0 0
1EBDCB84: 0 0 0 0 0 0 0 0
1EBDCBA4: 0 0 0 0 0 0 0 0
1EBDCBC4: 0 0 0 0 0 0 0 0
1EBDCBE4: 0 0 0 0 0 0 0 0
1EBDCC04: 0 0 0 0 0 0 0 0
1EBDCC24: 0 0 0 0 0 0 0 0
1EBDCC44: 0 0 0 0 0 0 0 0
1EBDCC64: 0 0 0 0 0 0 0 0
1EBDCC84: 0 0 0 0 0 0 0 0
---- block26 ptr=519B948 is_malloc=0 length=0x188 ----
519B908: 0 0 0 0 15A3C78B 1 1307EA0 51993A8
519B928: 0 1000002 5198235 301 12D8644 0 0 1000000
519B948: 519B9F0 519B8A0 519B928 51991F0 0 0 51972C0 5197188
519B968: 5197300 519739C 519B960 3D0D010 78 90000 3 0
519B988: 32EDE80 12CA308 12CA310 380238C 0 0 0 0
519B9A8: 0 0 0 0 0 0 15A3C78B 1
519B9C8: 1307EA0 51993A8 0 1000001 5198249 301 12D8644 0
519B9E8: 0 1000000 0 519B948 519B9D0 51991F0 0 0
519BA08: 5197494 519735C 51974D4 5199270 519BA08 3D0D010 74 90000
519BA28: 3 0 32EDE80 12CA308 12CA310 380238C 0 0
519BA48: 0 0 0 0 0 0 0 0
519BA68: 0 0 0 0 0 0 0 0
519BA88: 0 0 0 0 0 0 0 0
519BAA8: 0 0 0 0 FD0110DF AB1234CD FFFE0000 0
519BAC8: 32EDC24 1308000
---- block27 ptr=9FFFF9C is_malloc=0 length=0x164 ----
9FFFF5C: 0 0 0 0 0 1 0 0
9FFFF7C: 0 0 0 0 0 0 0 0
9FFFF9C: 9FFFEFC A00003C 0 0 0 0 0 0
9FFFFBC: 0 0 0 0 0 0 0 0
9FFFFDC: 0 0 0 0 0 0 0 0
9FFFFFC: 0 0 0 0 0 1 0 0
A00001C: 0 0 0 0 0 0 0 0
A00003C: 9FFFF9C A0000DC 0 0 0 0 0 0
A00005C: 0 0 0 0 0 0 0 0
A00007C: 0 0 0 0 0 0 0 0
A00009C: 0 0 0 0 0 1 0 0
A0000BC: 0 0 0 0 0 0 0 0
A0000DC: A00003C A00017C 0 0 0 0 0 0
A0000FC: 0
---- block28 ptr=58E0114 is_malloc=0 length=0x100 ----
58E00D4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E00F4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E0114: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E0134: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E0154: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E0174: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E0194: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E01B4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E01D4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
58E01F4: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block29 ptr=1F31CE94 is_malloc=0 length=0x100 ----
1F31CE54: 2440263E 9C3D2E3E 8403553E 64976F3E 34166F3E 54BB6C3E C489453E C801743E
1F31CE74: DC61193E E0C91C3E 54C1263E D81F263E 8CFC483E 8C4E233E 20346E3E 98937B3E
1F31CE94: F0CB2F3E 488203E FC3F2F3E A4E7243E BB3A3E B412253E E4CC3D3E C00E3A3E
1F31CEB4: 648A213E 5C3F533E 6C67763E AC13773E 7879703E 98CF703E 44F82B3E 50694E3E
1F31CED4: 78BB1F3E 28B8543E 4431443E 88E1E3E 4494E3E 7CF7583E 600C393E 5095183E
1F31CEF4: 7021543E 9C661B3E D42C303E B481783E 5472293E 743A5A3E 5CDA703E 30B4253E
1F31CF14: 58292A3E 83F213E 1022303E D82F513E 4028693E 9067293E 28F7263E 82C193E
1F31CF34: BCA07C3E 48C2343E D4B1683E 28331C3E C4502D3E 44D21B3E B8EF353E 6CA36B3E
1F31CF54: 28A54C3E 7F453E B0066D3E 48D8193E 28F4493E 9811203E 4C53253E E8446C3E
1F31CF74: 60C0183E 683E453E D4CA2A3E C89F6E3E 20113B3E F017503E C840463E AC78593E
---- block30 ptr=63F68C4 is_malloc=0 length=0x100 ----
63F6884: C3097E7 20313E3 6900001A 305098E5 60A0E3 473AA0E3 453E83E2 E3083E2
63F68A4: B3109AE1 1C21B38 E0200 20A0E3 953184E0 924520E0 65FFE7EF 1000000
63F68C4: 542601D1 10000 CAEFDC72 960124E0 A327A0E1 843882E1 342098E5 36082E0
63F68E4: 882088E2 180092E8 63093E0 40A4E2 180082E8 C3097E7 53E3 200000AA
63F6904: 103098E5 10013E3 1900000A 10856E3 168A033 473AA0E3 463E83E2 43083E2
63F6924: 3309AE7 30056E1 360A021 885088E2 F82098E5 180095E8 23053E0 C24FC4E0
63F6944: 180085E8 80329FE5 FE0A0E1 3F0A0E1 2611A0E1 74329FE5 FE0A0E1 3F0A0E1
63F6964: F80088E5 180095E8 3093E0 C04FA4E0 180085E8 E82088E2 183097E5 C34FA0E1
63F6984: 180082E8 5E3CA0E3 E83083E2 33097E7 10113E3 F00000A 903098E5 943088E5
63F69A4: 30A0E3 903088E5 F02088E2 E83088E2 30093E8 30082E8 20E0E3 10E0E3
---- block31 ptr=F24109C is_malloc=0 length=0x100 ----
F24105C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F24107C: FFFFFFFF FFF7FFFF FFFFFFFF FFFFFFFF FFFFEFFF FFFFFFFF FFFFFFFF FFFFFFFF
F24109C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F2410BC: FF7FFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F2410DC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFBFFF FFFFFFFF FFFFFFFF FFFFFFFF
F2410FC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF F7FFFFFF FFFFFFFF FFFFFFFF
F24111C: FFFFFFFF FFFFFFFF FFFFFFFF FDFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F24113C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F24115C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7FFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
F24117C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block32 ptr=199DB324 is_malloc=1 length=0xA00 ----
199DB2E4: 0 0 0 0 0 0 0 0
199DB304: 0 0 0 0 0 0 0 FD0110DF
199DB324: AB1234CD FFFE0000 0 32CF9F0 12253B4 199DBDE8 199DA874 8000054A
199DB344: 1 0 1000001 519B9D0 AFACEFAD 0 0 0
199DB364: 0 0 0 0 0 0 0 0
199DB384: 0 0 0 0 0 0 0 0
199DB3A4: 0 0 0 0 0 0 0 0
199DB3C4: 0 0 0 0 0 0 0 0
199DB3E4: 0 0 0 0 0 0 0 0
199DB404: 0 0 0 0 0 0 0 0
199DB424: 0 0 0 0 0 0 0 0
199DB444: 0 0 0 0 0 0 0 0
199DB464: 0 0 0 0 0 0 0 0
199DB484: 0 0 0 0 0 0 0 0
199DB4A4: 0 0 0 0 0 0 0 0
199DB4C4: 0 0 0 0 0 0 0 0
199DB4E4: 0 0 0 0 0 0 0 0
199DB504: 0 0 0 0 0 0 0 0
199DB524: 0 0 0 0 0 0 0 0
199DB544: 0 0 0 0 0 0 0 0
199DB564: 0 0 0 0 0 0 0 0
199DB584: 0 0 0 0 0 0 0 0
199DB5A4: 0 0 0 0 0 0 0 0
199DB5C4: 0 0 0 0 0 0 0 0
199DB5E4: 0 0 0 0 0 0 0 0
199DB604: 0 0 0 0 0 0 0 0
199DB624: 0 0 0 0 0 0 0 0
199DB644: 0 0 0 0 0 0 0 0
199DB664: 0 0 0 0 0 0 0 0
199DB684: 0 0 0 0 0 0 0 0
199DB6A4: 0 0 0 0 0 0 0 0
199DB6C4: 0 0 0 0 0 0 0 0
199DB6E4: 0 0 0 0 0 0 0 0
199DB704: 0 0 0 0 0 0 0 0
199DB724: 0 0 0 0 0 0 0 0
199DB744: 0 0 0 0 0 0 0 0
199DB764: 0 0 0 0 0 0 0 0
199DB784: 0 0 0 0 0 0 0 0
199DB7A4: 0 0 0 0 0 0 0 0
199DB7C4: 0 0 0 0 0 0 0 0
199DB7E4: 0 0 0 0 0 0 0 0
199DB804: 0 0 0 0 0 0 0 0
199DB824: 0 0 0 0 0 0 0 0
199DB844: 0 0 0 0 0 0 0 0
199DB864: 0 0 0 0 0 0 0 0
199DB884: 0 0 0 0 0 0 0 0
199DB8A4: 0 0 0 0 0 0 0 0
199DB8C4: 0 0 0 0 0 0 0 0
199DB8E4: 0 0 0 0 0 0 0 0
199DB904: 0 0 0 0 0 0 0 0
199DB924: 0 0 0 0 0 0 0 0
199DB944: 0 0 0 0 0 0 0 0
199DB964: 0 0 0 0 0 0 0 0
199DB984: 0 0 0 0 0 0 0 0
199DB9A4: 0 0 0 0 0 0 0 0
199DB9C4: 0 0 0 0 0 0 0 0
199DB9E4: 0 0 0 0 0 0 0 0
199DBA04: 0 0 0 0 0 0 0 0
199DBA24: 0 0 0 0 0 0 0 0
199DBA44: 0 0 0 0 0 0 0 0
199DBA64: 0 0 0 0 0 0 0 0
199DBA84: 0 0 0 0 0 0 0 0
199DBAA4: 0 0 0 0 0 0 0 0
199DBAC4: 0 0 0 0 0 0 0 0
199DBAE4: 0 0 0 0 0 0 0 0
199DBB04: 0 0 0 0 0 0 0 0
199DBB24: 0 0 0 0 0 0 0 0
199DBB44: 0 0 0 0 0 0 0 0
199DBB64: 0 0 0 0 0 0 0 0
199DBB84: 0 0 0 0 0 0 0 0
199DBBA4: 0 0 0 0 0 0 0 0
199DBBC4: 0 0 0 0 0 0 0 0
199DBBE4: 0 0 0 0 0 0 0 0
199DBC04: 0 0 0 0 0 0 0 0
199DBC24: 0 0 0 0 0 0 0 0
199DBC44: 0 0 0 0 0 0 0 0
199DBC64: 0 0 0 0 0 0 0 0
199DBC84: 0 0 0 0 0 0 0 0
199DBCA4: 0 0 0 0 0 0 0 0
199DBCC4: 0 0 0 0 0 0 0 0
199DBCE4: 0 0 0 0 0 0 0 0
199DBD04: 0 0 0 0 0 0 0 0
---- block33 ptr=91E8F18 is_malloc=1 length=0x4E4 ----
91E8ED8: 0 0 0 0 0 0 0 0
91E8EF8: 0 0 0 9B61420 42 91E8F48 91E8580 FD0110DF
91E8F18: AB1234CD FFFE0000 0 32CF9E0 1225354 91E93FC 91E8A48 8000025A
91E8F38: 1 0 1000001 519B9D0 0 1E30D96E 0 0
91E8F58: 9ADBA10 0 FFFF0000 10000 1E30D73C 1E30D8F4 1E30D94C 1E30D94C
91E8F78: 0 1E30D7C0 0 0 66EF478 0 1850001 E
91E8F98: 0 0 0 0 0 FF000000 0 0
91E8FB8: 0 0 0 0 0 0 0 0
91E8FD8: 0 0 0 0 0 0 1 0
91E8FF8: 6534194 0 188C094 14 1E30D96E 0 0 0
91E9018: 0 0 0 0 0 0 0 0
91E9038: 0 0 0 0 0 0 0 0
91E9058: 0 0 0 0 0 0 0 0
91E9078: 0 39C4260 0 39C4088 0 0 0 0
91E9098: 0 0 0 0 0 0 0 0
91E90B8: 0 0 0 6533684 0 0 0 0
91E90D8: 0 0 0 CEADEA5E 0 0 FACD1010 0
91E90F8: 0 0 0 0 0 0 0 0
91E9118: 0 0 0 0 0 0 0 0
91E9138: 0 0 0 0 0 0 0 0
91E9158: 0 0 0 0 0 0 0 0
91E9178: 0 0 0 0 0 0 0 0
91E9198: 0 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E91B8: FFFFFFFF FFFFFFFF FFFFFFFF FFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E91D8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E91F8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
91E9218: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 0 0 0
91E9238: 0 0 0 0 0 0 0 8BD0
91E9258: 0 0 0 0 0 0 0 0
91E9278: 0 0 0 0 0 0 0 0
91E9298: 0 0 0 0 0 0 0 0
91E92B8: 0 0 0 0 0 0 0 0
91E92D8: 0 0 0 0 0 0 0 0
91E92F8: 0 0 0 0 0 0 0 0
91E9318: 0 0 0 0 0 0 0 0
91E9338: 0 0 0 0 0 0 0 0
91E9358: 0 0 0 0 0 0 0 0
91E9378: 0 0 0 0 0 0 0 0
91E9398: 0 0 0 0 0 0 0 0
91E93B8: 0 0 0 0 0 0 0 0
91E93D8: 0 0 0 0 9B61420 42 91E942C 91E8A64
91E93F8: FD0110DF
---- block34 ptr=9ADA824 is_malloc=0 length=0x180 ----
9ADA7E4: 9ADA114 0 0 0 9ADA214 0 0 0
9ADA804: 9ADA7B4 0 0 0 9AD9844 0 0 0
9ADA824: 9ADAD24 0 0 0 9ADA394 0 0 0
9ADA844: 9ADA054 0 0 0 9ADA274 0 0 0
9ADA864: 9AD9974 0 0 0 9AD9854 0 0 0
9ADA884: 9ADA124 0 0 0 9AD98A4 916E624 0 0
9ADA8A4: 9AD9E14 91CAB1C 0 0 9ADAD04 0 0 0
9ADA8C4: 9ADA594 0 0 0 9ADA824 0 0 0
9ADA8E4: 9AD9B84 0 0 0 9ADA6B4 0 0 0
9ADA904: 9AD9E04 0 0 0 9AD9AE4 0 0 0
9ADA924: 9AD9F14 0 0 0 9ADA2F4 0 0 0
9ADA944: 9ADA884 0 0 0 9ADA354 0 0 0
9ADA964: 9AD9964 0 0 0 9AD9904 0 0 0
9ADA984: 9AD9774 0 0 0 9ADA444 0 0 0
---- block35 ptr=A4B7144 is_malloc=1 length=0x5FC ----
***** End of Crash File dump *****
Thanks for the log.
There is one detail which sounds wrong to me, those lines here:
*May 9 07:31:41.347: Writing //AP188b.9d5c.dec0M_WLC09052018_073141.pcap
*May 9 07:33:42.195: Writing //AP188b.9d5c.dec0M_WLC09052018_073342.pcap
It looks as if the AP is in some sort of sniffing mode?
My APs don't crash often enough for me to have a logfile to compare, but it looks weird. If you haven't already, open a TAC.
@patoberli - we have an external logger, not sure its realted though, as only specifc ap's tend to reboot.
And what does the external logger log?
I'm asking because the .pcap files are actually network capture files, which you could open in Wireshark. Or do you mean with an external logger a Netflow capable device where you log all the traffic?
If so, could you, just for testing, disable this for a few APs and check if the crashing stops?
hi, it was few weeks now with the logger turned off
it seems to solve the issue !
my guess it that intensive log capture was causing some AP's to memory leak, and crash.
Thanks!
