WLC 4400 simultaneous users
aalejo
Level 7
Level 7
Does somebody knows how many simultaneous wireless client the WLC 4404 support?
beth-martin
Level 10
Level 10
The limitation of the number of supported APs is based on the hardware that you have. The 4402 WLC with two Gigabit Ethernet ports comes in configurations that support 12, 25, and 50 APs. The 4404 WLC with four Gigabit Ethernet ports supports 100 APs.
Stephen Rodriguez
Generally, the recommended number of clients per AP is about 15. This is only a recommendation though, you can have more than that connect to a single AP at one time. So from that logic, a 4404 would support upwards of 1500 concurrent client connections. I don't know that I've seen any real limitation on this, but you will eventually saturate the gigabit ports to a point where everyone notices some degredation.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
