WLC 4402 + ACS 5.4 + AD: is it possible to use separate ip dhcp pools according to AD user group?
Ivan Rezvantsev
Hello, we are using WLC with ACS and it is working well.
We have AD group WiFi_access, and all users from these group are able to athunticate during connecting to corporate wifi network.
How we could make, for example, two AD groups: WiFi_access and WiFi_VIP and users from first group get 10.7.0.0/24 adressess and 10.8.0.0/24 from the second? or it could be 10.7.0.0-100 and 10.7.0.100-200 it doesn't matter.
the main goal is: different AD groups of users must have different privileges and these is controling via ACL on their default gateway switch.
Rasika Nayanajith
You can use "aaa-override" feature to do that. In that case once user get connected & if he is belong to "WIFI_VIP" group ACS can override the user vlan to a different one (10.8.0.0/24) what they initially associate to.
You can get an idea about the concept from the below post
http://mrncciew.com/2013/05/21/aaa-override-in-acs5-2/
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
thank you very much its working fine.
