The 1010 aps connect to the switches as hosts
(switchport mode access; switchport access vlan ...)
The controller has 2 ports that connect to the network as trunks. You can connect them as port 1 and 2, or put them in a lag group [aka etherchannel)
All the vlan trunking is done at the controller port to switch port. The AP sends the info down to the controller over the vlan specified for the aps
In your case, you should create another vlan for the APS.
The 4402 controller mgmt interface would sit in the same vlan as the APs. You would then create dynamic interfaces on the controller that have a vlan id and ip address for the desired network per your needs. You would then create a wlan on the controller and then bind it to the dynamic interface you just created.
I am oversimplfying this process quite a bit, but it should get you started. There is now a good bit of info on cisco.com for the wireless products
