WLC 4402 is not working
Muthukumar P
         We have two 4402 WLC , one is online another one is standby.. stand by WLC is not syncing with wireless AP.. If conneced the same port & same switch which one is working wlc but nor syncing with AP.. For your reference i have attached the document ..Please do the needful.
Muthukumar
+91 9790929141
Muthukumar P
I Have attched working WLC configuration attached for your reference..
Muthukumar
Scott Fella
The 4400 controllers don't have a sync between the two controllers. The AP's joined to one controller is managed by that controller only and doesn't sync to a backup. If an AP fails to the backup, then the AP gets its configuration from that controller not the previous. In an N+1 design, both controllers need to have the same configuration except for hostname, IP address, and multicast address.
-Scott
-Scott
HI,
    I have attached Wireless AP model and firmware version and collected the show clock command output, it looks time is mismatched between AP and WLC but i am getting confuse how its work with one controller and why it's not working another controller even same config include host name also same..Please help to resolve the issue..
NX_6th_1>
INX_6th_1>sh
INX_6th_1>show clo
INX_6th_1>show clock
*00:00:19.397 UTC Fri Mar 1 2002
INX_6th_1>
INX_6th_1>
INX_6th_1>
INX_6th_1>
Muthukumar
Host name and IP address need to be different between the two controllers. How it works with one controller and not the other can be that the other is not configured right or maybe it's not functioning properly anymore.
-Scott
-Scott
