WLC 4404 port reset?
mbhnt
We have a WLC 4404 and had a dodgy Gbic that caused the port to go down, but now we can't get the port to come back up.
Do you think reloading the firmware will reset everything?
irisrios
Level 6
Level 6
Removing the GBIC and reloading the controller should help you in this case. Software has not got anything to do since it the problem is with the physical connection.
