WLC-5508 Authorization failed to create SSID
xs.gautam
Hi All,
I have two WLC-5508 for 50 AP's deployed. One is primary controller & other is secondary.
Recently noticed an unknown "authorization failed, no sufficient privileges for user" message poping up while making configuration changes
in WLC. Specificly when trying to create an new SSID. WLC Authentication is local. This message poped up earlier once or twice but it didnt prevent
from making changes that time.
How to troubleshoot ?
Gautam
Scott Fella
Do you have any radius configured on the WLC by chance. If so can you make sure you don't have management checked there. I have not seen that issues with the 5508 and any of the 7.x code as of yet.
-Scott
5 Replies 5
Scott Fella
-Scott
Did you configure privilege user account on TACACS to manage specific WLC feature.
Security>> priority order>> management user>> do you see only local and or tacacs.
Help!
I have Cisco 5500 Version 7.5
I log in using the admin settings Security >> priority order >> management user >>.
But can not save save config
Menu
Thank you
Thanks Scott, I just found that management box was checked . Issue is resolved now.
Where is this management box?
